Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Gotta say I agree on this one. The Aqua Computer res is expeeensive, but come on - the REAL glass is exactly what this mod needs. Pure class.
  2. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks! :)
    I was also a bit worried while "working" with the reservoir as it seems is going to crack anytime!
    I was in love when I first saw the golden fittings! :D
    I ordered directly from Bitspower but sometimes you are not going to get any answers, be ready for that!
    Also I did some orders to Aquatuning ;)
    Thank you a lot :)
    I was not aware of the Aqualis and the new AQ stuff and it looks great!
    I will try to adapt my build for the Aqualis reservoir but that little update will be after the summer probably since my loop was planned with the EK reservoir options and size :)
    I'm sorry that I haven't posted any updates but I'm waiting for 2 pieces to continue with this build.
    I already did leak test and so far so good. I'm only having some drops leaking when I use pumps at minimum speed... when I kick both pumps to work at max RPM then there are no leaks :confused::confused:
    I will try to check the leaking area (above the AQ5 where the Top rad connects with the aquaero bridge)
  3. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hello everyone!
    I have some updates!
    I planned this midplate long time ago and I already had it at home for almost 2 months but I couldn't use it because still had to measure where to fit the reservoir + pump + SSD's etc..
    Here is the first hole, this will help me to connect the pump + reservoir combo with the lower section
    First cut done, now planing how to connect the lower section with the top section again to continue with the loop.
    Also need to do some holes to allow GPU wires to connect to the graphic cards...
    More cutting for this evening!
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    ooo exciting times ahead!
    Cheapskate and Waynio like this.
  5. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Yes :rock::rock:
    Midplate ready!
    Trying some fittings to see which ones fits better
    Midplate to radiator closeup pics
    Second bottom radiator has a flow meter and inline water temperature sensor!
    Tomorrow more!
  6. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Som
    just LUUUURVE this build giving me real inspiration to try and finish mine- had a little leaking issue with the AQ5 block leaking and a rad leak on top of surgery last week to hopefully correct a badly mangled shoulder so am a bit behind the times:wallbash:
    Was thinking about possibly doinga midplate type thingy as well but won't be anywhere near the quality of yours
    Keep up t'good work my man:thumb:
  7. Cheapskate
    13 May 2007
    The color scheme is really snazzy. :D
  8. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you for the nice words!
    I really encourage you to work on a midplate since it makes a whole lot of difference once mounted, everything is much better and looks so clean! :D
    :brrr::hip::thumb:
    More pictures of one of the custom pieces I was waiting!
    This was made by E22, hope you like it
    Front
    Back
    Heatsink... what for?
    50mm fans connected in series
    Doing some tests with cables
    Sleeved!
    So this is the final design for the Dual 35x pedestal and I really love it!
    I plan to add a sensor between the pumps and the heatsink and see what temperature reading I get! :)
    More coming soon! :rock:
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    That is really awesome mate :D I shall have to let Nate make me something some time for sure, he is producing some seriously sweet pieces, did you design it & send him the design or did Nate design it, really it's gorgeous & awesome. :rock:
    +rep to you & Nate. :D
  10. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you Waynio!
    Really the design is all made by Nate, I just sent him a rough idea of what I wanted and then just let him do his magic lol.
    I will post some of the quick drawings I made (Lego box render style haha)
    Here is another of Nate's work and the final piece of the puzzle.
    I wanted a housing for my dual PSU starter so we decided to work on something unique, and after all the hard work and e-mails this is what he made, enjoy:
    I will put those holes you see there in a good use, I will show you later.
    This is the PCB that I will install inside the enclosure.
    Ready to be installed
    Installed!
    Ready to be connected! :rock:
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    Very nice. :)
    All good designs are born from rough good :idea: not all good designs become real things but when they do. :jawdrop::clap::rock::hip::D
  12. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Looking stunning mate.
    Have decided I will be getting either this case or the XSPC H20 Tower+, for my build and might do some modding on it but not sure yet but your build is inspiring.
  13. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you very much Waynio :))
    Thanks damien, I really like the Little Devil and I also did a lot of reserach before I placed my order and I think Little Devil has all what is needed for watercooling (and more!)
    Another small update, I've installed the custom PCB holder between the two rads and also connected all of the 24 pin cables aswell.
    The custom piece is fixed directly to the radiators (into the fan threads) and the rad sits on top of the two radiators.
    Those big holes are to allow tubing to pass and will help me to fix the tubing in place and avoid "dancing tubing" inside the case :D:D
    Here the connector and the extenders ready to recieve the tubing!
    The end is near, stay tuned! :rock:
  14. Cheapskate
    13 May 2007
    Rep'd for throwing money at Editor22.:D More people need to do that - fun things happen.
  15. Telefonskaft
    Telefonskaft What's a Dremel?
    31 May 2011
    Damn that looks awesome! Can't wait for next update :D
  16. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you guys, Editor22 deserved some of the budget of this build lol
    Some more pictures while I have everything else ready:
    When you awake the little angel, this happens:
    I promise to post more pictures, all my pictures are teasers and I know lol
  17. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Great Work. The case looks great!
  18. Editor22
    3 Jan 2009
    Looks awesome dude! I never got time to test out the lighting effect but seems I had no need to worry :D
  19. wratterus
    wratterus What's a Dremel?
    2 Jun 2011
    Looking amazing, mod on! :D
  20. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks!
    Hey Editor22, everything is working great!
    I'm already thinking about the next custom piece for revision lol
    Will do!
    After so loooooooooooong and lots of hours and money I can say that Little Angel is almost finished, 90% that is, let me show you some picture before I show everything else but need to repaint some stuff :)
    Hope you like them as much as I did taking them ;)
    Thanks for following the work, the end is near :)
    Squigly and Nutman like this.
