Case Mod - In Progress "Little Angel" - * COMPLETED! - Final pictures pages 20 & 21 *
Discussion in 'Project Logs' started by xSoMBrAx, 8 Oct 2011.
What to do: Black or white tubing!?
  1. Black!
    26 vote(s)
    40.0%
  2. White!
    36 vote(s)
    55.4%
  3. No idea, I hate water cooling!
    3 vote(s)
    4.6%
  1. KidMod-Southpaw
    28 Sep 2010
    Good stuff! Now get them in the system! :p
  2. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I want more :D!!!
  3. peteski
    peteski long live the pc
    8 Jun 2011
    nice box of bits mate cant wait to see them in side the case :rock: :rock: :rock:
  4. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    - Sponsors -
    [​IMG][​IMG][​IMG][​IMG]
    [​IMG] [​IMG]
    Aquatuning España / Atlas Informática / NZXT
    ProSilentPC / Seasonic / IzarMicro
    Gracias a todos los sponsors por colaborar en el proyecto.
    Many thanks to all the sponsors for the support given to this project
    Thank you guys!
    Update for you!
    First test with radiators in the bottom section of the Little Devil
    There is a lot of space down there... Enough for paralel 19/13 tubing :)
    Taking measurements and starting the work
    Just want to keep about 8cm of fan cable!
    White tape to get a much pleasent sleeving result
    Sleeved and with half heatshrink!
    Because of the sleeving we need to cut plastic so the cable will sit on its place :)
    Done!
    Just need to cover the fan PCB... soon!
    Stage 1 complete!
    Stage 2 begins!.
    The reason to do the sleeving this way is to keep the fans easy to remove and change in the future. If I just solder all the fans together in series it would be a pain where_you_know to remove or change fans or any other stuff fan related, that's why I created that custom splitter!
    Couple of hours after, sleeved splitter!
    Finally a connector detail, might remove the extra heathrink with a sharp blade so you will not see that extra shrink :)
  5. KoSoVaR^
    19 Dec 2010
    Very handy and tidy!
    I like it alot!
  6. peteski
    8 Jun 2011
    great work mate keep it up :rock: :rock: :rock:
  7. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you both :)
    Working on the 2nd radiator right now, will post pictures when finished and then will start to sleeve the last radiator :)
  8. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hello everyone!
    I would like to introduce you IZAR MICRO , they are my new sponsor!
    They helped me a lot since day 1, many thanks to Jon.
    Will upload some updates later!
  9. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Another small update, just finished sleeving the 2nd radiator, just one more to go :wallbash::wallbash:
    I began this one in the morning...
    Finished at night :rock:
    (I spent 8 hours at work aswell so was quite good :D)
  10. KidMod-Southpaw
    28 Sep 2010
    Woah, great job! That looks very neat and tidy!
  11. peteski
    8 Jun 2011
    keep up the good work mate :rock: :rock: :rock:
  12. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks!
    Tonight I will finish the last radiator (hopefully!) and will post pictures :rock:
    After that will plan the front fan sleeving and other stuff that needs to be sleeved :wallbash:
  13. Martininho
    Martininho What's a Dremel?
    8 Feb 2012
    Nice work, Could you post some closeups of the ends of the wires? Wondering what you are doing with those. Fairly new to that stuff, hence the question.
    Mod overall looking really good!
  14. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Sure have a look:
    As you can see I've soldered the positive and negative of each fan in series, that is why I had to make my own splitter of desired length, everything looks much better now :)
  15. Martininho
    8 Feb 2012
    Nice, looks good indeed. Cant wait to see what you turn out with! :rock:
  16. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thank you Martininho :)
    Today I recieved something that I did not expect to get so fast...
    TEASER!
    And finally a making-off shot from the "sleeving nights" :D:D
    Will have to wait before I can show some progress, need to wait for some stuff but before that I will keep planing and routing things
    Have a nice weekend..
  17. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Hello guys!
    Long time since my last update... I was waiting for some tools and still waiting for my Aquaero 5 so I can finish all the connections (need to measure all the wire lengths depending on the AQ5 final placement)
    While waiting I decided to do some wiring of the Power Adjust 2, still need to connect the Aquabus in series, I'm waiting for some black pins :wallbash::wallbash:
    Black screws and black PA2 faceplate...
    Black MOLEX connector and pins!
    Will get rid of the ULTRA stickers soon, don't worry.
    Custom length cables are great but a pain to measure and make them look good hehe. 12V power in series for all PA2
    Detail of the final molex connector that will "feed" them :)
    Not going to sleeve any of the PA2 connections since I think they look great with white cable.
    Soon more to come! :rock:
  18. KidMod-Southpaw
    28 Sep 2010
    Looking good!
  19. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    This is really fantastic xSoMBrAx I totally agree that the white cables look great just the way they are :)
  20. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Thanks KidMod :)
    Much appreciated Editor22... I've seen your work and it's amazing, the renders and the custom acrylic work... I'm sending you a PM right now! :)
    I thought that I had no 3 pin connectors but I managed to find some so I could link the Aquabus lines from the PA2
    Pins and connectors
    My tools for my custom length wires... really need to get some good wire stripper to have all with exactly the same length, that could improve the results even more. Knipex maybe?
    BEFORE
    AFTER!
    Aquaero 5 XT is on it's way as I said yesterday, still need to make 1 more custom connector that will link all the PA2 with AQ5 and make them work as one pice of hardware :cooldude:
    peteski likes this.
