Cooling Little diamond cpu cooler
Discussion in 'Hardware' started by technogiant, 4 Jul 2012.
  1. technogiant
    technogiant What's a Dremel?
    2 May 2009
    It's not a bug, I have very good gpu temps as well, 2 gtx 460's in sli. Ive overclocked them from reference of 675 to 875Mhz
    They run furmark multi gpu at about 30 deg C as well.....they are bog stock palit sonics with a soild heat sink
    I just think solid heat sinks are better than heat pipes and vapor chambers
    My case helps to I made it myself.
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    Put your hand to the heatsink, does it feel like it's 30c?
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Any chance of a picture of the hand built case, might add more clues to the mystery.
  4. technogiant
    2 May 2009
    I can't...its inside my case.
  5. docodine
    10 Feb 2007
    My bet is that it's a hollowed out block of ice :lol:
    Anyway, technogiant unless if there's a major factor that you've left out there's no way you're getting those temps. Your sensors must be wrong, or your settings must be wrong, or something..
    Just think about it, how can you be getting sub-ambient temps with air cooling? Do fans and blocks of copper actively cool hot things or do they work to wick the heat away?
  6. technogiant
    2 May 2009
    I'll post one now hang on
  7. technogiant
    2 May 2009
  8. technogiant
    2 May 2009
    Sealed chamber build using stripped down ac unit......gets internal temps of -28 to -22 deg c
    all components air cooled...have to use solid heat sinks as heatpipes and vapor chambers freeze up...lol sorry guys
  9. docodine
    10 Feb 2007
    :lol:
    10/10
    The mystery is revealed
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I knew there was a trololololol in here somewhere :p
    And dude, you seriously need to sort out that things looks...
  11. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Is that what that is, lol, I must admit to having mouthed the words WTF :)
  12. technogiant
    2 May 2009
    Yeah sorry guys I've only recently built it and just felt like a little fun...albeit at your expense.
    CrapBag likes this.
  13. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    You troll good :) :) :)
  14. Bloody_Pete
    11 Aug 2008
    I've always wanted to do this, but usingAlu and Plexi so you can see it...
  15. technogiant
    2 May 2009
    Yeah its a complete Frankensteins monster.......but at -28 deg C do I give a ****
    And i didn't show you the best bit I've got a green space hopper attached to the chamber by a breather pipe as an expansion chamber...lol
  16. technogiant
    2 May 2009
    You've got to have insulation in there, the lid has got a viewing window ....2 sheets of plexi separated by a 50mm air gap...that still gets condensation on the outside.
  17. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Well trolled sir, have some rep :thumb: :hehe:
  18. technogiant
    2 May 2009
    Cheers lancer...just down the road from you, Newport......was born in Cardiff.
  19. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    .....and I'm just across the severn, walk 2 mins from my house and I can see both bridges :)
  20. technogiant
    2 May 2009
    Then you'll probably be able to hear my ac unit running....not a quiet system...lol
