Notebooks Llano successor arrives: Trinity
Discussion in 'Hardware' started by Chicken76, 15 May 2012.
  1. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
  2. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    But it looks like it isn't too good either. Did they learn nothing from the Pentium 4? Pushing for higher clockspeeds is a good way to ruin your per-clock performance. They should be pushing for ever lower clockspeeds while increasing overall performance at the same time.
    EDIT: I should add that I think Trinity will definitely have a place in low to mid range notebooks, but it all depends on how well the rest of the Ivy Bridge line fleshes out.
  3. Chicken76
    10 Nov 2009
    Well, they improved IPC, graphics performance and power consumption, so it's better in every way than Llano.
    And all of this was achieved while using the same 32nm process. Sure, the improvements are not huge, but they are there on every front.
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Llano wasn't actually that bad. it's a wonderful all-in-one chip for media boxes and the like, simply because the igpu isn't pants.
    If the new version is even faster; I can see it doing well. The better IPC and power consumption definitely makes it attractive to me, i might build a little media server with one when I've got the money.
    Piledriver, on the other hand, had better be a good leap above Bulldozer. It'll still be gimped, though. The Northbridge on most 990FX motherboards simply doesn't run fast enough, so it bottlenecks the crap out of the memory. Plus Bulldozers memory controller wasn't that good anyway, so if you removed that bottleneck; you only got a percent or two better speeds out of it.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    Just like Anand's conclusion says, if the price is right it's a winner.
    I'm disappointed that it didn't beat Intel's offerings overall, moves like this are what lets Intel get away with the crap they pulled with IB...
  6. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    I keep saying this but...
    One of these days I'm gonna get around to making an Emulation/HTPC box, and when I do, I'll be putting an AMD APU in it.
  7. faugusztin
    11 Aug 2008
    The question is - why would you need APU for HTPC ? Even G530 handles all HD content without an issue. G530 on Asrock z68 itx board - 35W while idling on xbmc main screen, 36W while playing SD content, 38W while playing HD content, 39W while playing Samsung Oceanic HD content.
    The only place where i can really see Llano and Trinity as usefull alternatives are laptops or cheap gaming computers, where you need a bit of gaming performance but don't want to pay for a discrete graphics card.
  8. Neogumbercules
    14 Aug 2004
    Because there's always the possibility that I would want to do some low-end gaming with "real" games from the comfort of my bed/couch. AMD's APUs offer a cheap and easy path to have decent enough performance for when I'm feeling lazy.
  9. adam_bagpuss
    24 Apr 2009
    built my HTPC for under the TV couple of months ago and funnily enough i put a APU in it.
    A6-3500 i think. No complaints it plays everything flawless and general browsing etc is sexy smooth.
  10. mrbungle
    20 Sep 2004
    That's a hell of a niche market though lol
    I too don't see much of a point for them in all honesty in a desktop / htcp situation.
    Not very powerful as a cpu and not really powerful enough for modern games.
  11. Elton
    23 Jan 2009
    I could use this to play older games on a couch.
    I'm sure it's worth it.
  12. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    I think the target is laptops. About 100 times ts market of htpc which will play some games.
    Low power consumption is the big issue with laptops, and integrated graphics means no dedicated chop. Meaning smaller package, less heat and in turn, less heatsink occupying space.
  13. rollo
    rollo Modder
    16 May 2008
    Intel and AMD are no longer in the same market so expecting them to compete with intels high end is expecting way too much
    amd said it themselves that they wont be pushing the high end market anymore
