Electronics LM3914 Voltage Monitor tutorial question
Discussion in 'Modding' started by pascalek, 29 Dec 2004.
  1. pascalek
    pascalek What's a Dremel?
    24 Nov 2003
    Hi !
    I' ve found this easy tutorial: link
    but I've still got a problem, according to what I think the RLO is 0V, so the lowest diode of bargraph will be the only one litted only at 0V, right ?
    So, I think I have to put in a resistor before the RLO, but what value of resistor should I use ? (yeah I'm newbie at electronics :wallbash: )
    Thanks for any help, Greetz
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Welcome to Bit-Tech, pascalek! :thumb:
    Yes, your resistor is needed to raise the zero point. From this guide,
    For best accuracy, use a preset (trimmer) pot that covers the calculated resistor value.
  3. pascalek
    24 Nov 2003
    Thanks cpemma, but as I said I'm a newbie. I want to make RLO around 5 Volts (cause that will be the lowest voltage in my LM317T fan controller). So will this be ok for R2:
    The shop selling them says they are precise, mounting, cermet. I think the best value would be 10k (also available are 1k, 2k, 5k, 50k and 100k). Am i right ?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The 10k is the one to go for. Assuming maximum output from the 317T is 10.5V, the full 10k will give a minimum at 11/20 x 10.5 = 5.8V, any adjustment will reduce the minimum so 5V min is easily set.
    :read:
