Networks Logging into mac from Asus router
Discussion in 'Tech Support' started by happyhammer7, 3 Feb 2015.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    Hi guys,
    I am absolutely stumped on this and really need some help. I brought an asus router, which includes a feature called AIcloud. Now, this feature allows you to access shared folders on the mac through the router itself.
    Now I have a sinology disk station and i can login into this, no problem.
    However, for the life of me, I cannot login to my Mac Mini.
    This is the login screen.
    https://www.dropbox.com/s/gdb6npl2wgldrkq/Screen%20Shot%202015-02-03%20at%2019.00.42%20copy.png?dl=0
    Under my computer name in system preferences, it is set to "PaulMac"
    What format should i enter the username?
    As an example, my short username is paulsmith
  2. saspro
    saspro IT monkey
    23 Apr 2009
    I'm guessing it doesn't like the AFP format or the mac is going to sleep.
    Have you looked at Spotdox? That'd get you access to the files.
