hi guys im having problems with my g15, its never done this before but i have recently upgraded to windows 7. basically after a few minutes without touching the keyboard, the volume knob and media keys become unresponsive. only when i click the sound bar do they become responsive again. its very annoying because i use spotify in the background most of the time, and i cant skip track or change the volume without changing it manually. after a manual skip or manual volume change, everything works fine for a few minutes. help
Not had that problem and have been using G15 on Windows 7 64bit for a while now. Sounds like something else is hooking the audio control until you bring it back to focus again. Have you installed any other media program since it last worked correctly? Also, check your plugins are loaded correctly for the G15 and/or reinstall drivers.
