Hardware Logitech G710+ review
Discussion in 'Article Discussion' started by Meanmotion, 21 Mar 2013.
  1. Dedlite
    Dedlite What's a Dremel?
    4 Apr 2010
    Doesn't happen to me - I've had one for a few months.
    The box tells you you it's Windows 8 compatible, which is nice - my previous Sidewinder X4 isn't.
  2. mike_dowler
    mike_dowler What's a Dremel?
    17 Mar 2006
    How on earth can a keyboard NOT be Win 8 compatible?
  3. longweight
    7 May 2011
    THAT is a big keyboard.
  4. The_EXorcist
    The_EXorcist Possibly Australian
    14 Oct 2008
    Think i'll stick with my G-15 (Gen 1)
  5. Sni9er
    Sni9er Ermmmm 42 ???
    16 Apr 2009
    looks like a shaved down version of the corsair k90, even in use positioning of usb passthrough, and the volume roller.. even the banks of available macros
    wonder if both are just the same tech haha !
  6. Roskoken
    Roskoken What's a Dremel?
    15 Jul 2011
    found an old HP keyboard in a charity shop for a fiver, have not noticed my gaming getting any worse, weird.
  7. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    Decent buckling spring boards go for way more than that. M13's, Model F AT's and M15's (Think £500+ for the latter). Capacitative boards like Topre are expensive too. Quality is not, and never will be, cheap. Having used a Model M for 15+ years, I -can't- use a cheap keyboard now... my fingers hurt afterwards.
  8. Elton
    23 Jan 2009
    Tell me about it. :D
    Still rockin an Original Model M. They're cheaper than MX boards if you can find one on a lucky sale and they're usually fantastic.
    Just clean it.
  9. InSanCen
    30 Mar 2005
    Yeah, I now have 2 model M's, an M13, Model F AT, and a number of cherry switched boards and a few other weird ones.
Tags: Add Tags
