Logitech MX1000 , Steelpad 4S
Discussion in 'Hardware' started by WaLLaWaLLa92, 30 Jul 2005.
  1. WaLLaWaLLa92
    WaLLaWaLLa92 What's a Dremel?
    27 Jul 2005
    I was wondering if any1 knew if the mx1000 will work well on the steelpad 4S or even atall :S , Steelpad clearly states that , i quote , " *Does not work with Logitech Optical mice OTHER than the MX Series*" , So my question is seeing as the MX1000 is laser , not optical , but clearly is in the logitech MX series , whether it will work on this mat , cud any1 help?? , thnx.
  2. bwgames
    bwgames Minimodder
    6 Dec 2004
    laser is just another form of light, so it should work...
  3. bwgames
    bwgames Minimodder
    6 Dec 2004
    Oops, sorry, I see what you're getting at now.
    Just googled and found http://www.earthv.com/articles.asp?ArticleID=2290&PageID=2
  4. WaLLaWaLLa92
    27 Jul 2005
    Guessing tht the MX1000 wont work with Steelpad 4S (allu) thn , Ill try the steelpad 4D insted alot cheaper , and made of smotth flat plastic shud do the job , thnx :D.
  5. WaLLaWaLLa92
    27 Jul 2005
    Well I Got My Pad , And Its Fine Working On The Plastic Pad as i assumed , so thnx , happy mousing 4 me :D
