Logitech Z5500 speakers, thinking about getting them, just wanted to check first if i can connect them to my panasonic viera tv? anyone know, if so how? many thanks
No idea what outputs are on that TV, but the control pod has optical digital (toslink), coax digital, and 3x stereo analog which can either be three discrete sources or one 5.1 source (ex. soundcard). I think most HDTVs will use the optical toslink connection, but you'd have to look at the TV outputs to confirm that.
i dont know what connections your tv has, but the z5500 comes with the following inputs: 1: 3x 1.5mm jacks(headphone standard) which are usually used when connecting to a pc. 2: Optical in 3: A coaxial input (normally used on hifi equipment and should be present on tv as an input by standard along with the red and white connectors) just check the tv spces if you arent sure. i'd google the specs myself but it is your problem and i'm tired, so if you provide the specs or a link to them, i'll happily check them and make my recommendation. as it is i can vouch for the z5500 as i've had mine for 2 years now and they are great, for gaming and movies. peace fatman
