Hi all, Im in the process of setting up a home cinema in my room, which will (hopefully) include an audio feed from my pc into my home cinema amp. I was hoping to also keep my PC's 4.1 speaker system running and choose between those and the home cinema. I therefore concluded that the best thing to do was run from the digital output on my Audigy 4 into the optical or coaxical inputs on the amp. Aside from the fact I am going to have to buy a seperate I/O box that converts Creative's 3.5mm output into the standard phono or optical connectors, I am also having difficulty finding a long enough stretch (needs to be at least 10m) of either coaxial or optical cable. The most I seem to be able to find is 5m. Can anyone tell me if there is some limitation on how long these cables can be? If not where I would be able to get some cable long enough for the job? Cheers, /A
Try Here No idea how good the quality of it will be, but i'm sure its not the only one on Ebay if you have a better look than i did.
