Other Looking for a 5 second circuit
Discussion in 'Hardware' started by rivy1992, 30 Nov 2008.
  1. rivy1992
    rivy1992 What's a Dremel?
    30 Nov 2008
    Hi folks,
    I'm new here and I need some help. I am stumped on a project. I am trying to build a 5 second timer that is turned on by a voltage change from 12 VDC to 13.8 VDC. When the voltage change is sensed by the voltage comparator, two things happen a buzzer and a timer will turn on. After the 5 second delay, the buzzer must turn off. I have tried to build this circuit in MultiSim and am successfull creating each portion individually. However, when I try and put them all together it doesn't work. I really could use some help here. I am using a voltage divider to run the comparator and a LM555 timer to run the 5 second timer. I am also using a low voltage buzzer (I think it is 5 VDC) in the circuit and a low voltage relay (3VDC). Any help from one of you genius' would be greatly appreciated!!!
    Thanks,
    Rivy1992:worried:
  2. pdf27
    pdf27 What's a Dremel?
    6 Jul 2006
    Any chance of a circuit diagram for the whole thing?
  3. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Theres no need to post the same question in two different threads in two different forums, people who want to answer your question will find it even if you only post it once and people who don't will just find it rude.
    Moriquendi
  4. rivy1992
    30 Nov 2008
    sorry
    ok, sorry, like I said I'm new. Thanks for the advice.
  5. rivy1992
    30 Nov 2008
    I am at work right now but I will try and post it here in a little bit
