Electronics Looking for a 5 second timer circuit
Discussion in 'Modding' started by rivy1992, 30 Nov 2008.
  1. rivy1992
    rivy1992 What's a Dremel?
    30 Nov 2008
    Hi folks,
    I'm new here and I need some help. I am stumped on a project. I am trying to build a 5 second timer that is turned on by a voltage change from 12 VDC to 13.8 VDC. When the voltage change is sensed by the voltage comparator, two things happen a buzzer and a timer will turn on. After the 5 second delay, the buzzer must turn off. I have tried to build this circuit in MultiSim and am successfull creating each portion individually. However, when I try and put them all together it doesn't work. I really could use some help here. I am using a voltage divider to run the comparator and a LM555 timer to run the 5 second timer. I am also using a low voltage buzzer (I think it is 5 VDC) in the circuit and a low voltage relay (3VDC). Any help from one of you genius' would be greatly appreciated!!!
    Thanks,
    Rivy1992 :wallbash:
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Show us what the individual circuits look like, and how you stuck them together. Probably just a small thing you need to change to get it all working.
    You're in logs not modding btw, a mod will probably move it there when they notice it.
  3. rivy1992
    30 Nov 2008
    Thanks, sorry for the screw up. I forgot my flashdrive ast home and I am at work. I wrote my partner an email to sentd me the schematics in a word document so that I can post them here. She should send then to me within the next 15 minutes and I'll post them right away. Briefly, what I am trying to do is when a car starts, the voltage change in the output of the battery increases frrom 12 to 13.8 VDC. I want to use that change to drive a buzzer that will stay on for only 5 seconds and then turn off. Once the car is turned off, I want the circuit to re-set so that every time the car is turned on, the voltage increase can be detected and sound the buzzer.
