Electronics Looking for a cable...
Discussion in 'Modding' started by Cyprio, 9 Apr 2009.
  1. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    Hey all,
    I am looking for a cable to allow me to mount my Aquaero LCD display separately from the controller unit. I think i need something like this: http://www.pololu.com/catalog/product/973 but cant seem to find one in the UK or ebay.
    Any ideas?
  2. Cheapskate
    13 May 2007
    Make your own.:D They are easy. The connectors keep the cable lined up as you squeeze them over the wire.
    Connectors
    Wire Or find an old floppy cable and just peel off the # of wires you need.
  3. Cyprio
    2 May 2006
    Thanks cheapskate. I looked at IDE cables and the pins seem to have the same spacing. Do you think i can just cut one down to 16 pins and use that?
  4. Cheapskate
    13 May 2007
    I don't think one of the newer, super-fine IDE cables would work, but old floppy cables are compatible with the connectors I posted.
    If you are asking if you can cut the connector down too- no, you can't do that. :)
  5. Cyprio
    2 May 2006
