Notebooks Looking for a decent laptop
Discussion in 'Hardware' started by Ploo, 14 May 2011.
  1. Ploo
    Ploo What's a Dremel?
    1 Oct 2009
    I'm looking for a laptop to buy and I'm really hating it. With computers you can pick out the perfect parts, order them and build yourself a perfect PC but choosing a laptop is a horrible experience so I was hoping someone could recommend me something. This will be used as a replacement for my desktop until I can afford a decent PC but also needs to be something portable I can use in lectures and so on.
    Looking for:
    Decent performance
    Silent, light and portable.
    Quite small, i'd say 15.4" screen, maybe a bit bigger but probably not 17"
    Capable of casual gaming, nothing amazing
    Probably a dedicated GPU but I'm really not sure of how good integrated graphics is nowadays
    Budget is anywhere between £600-£900, depending if the price is justified. If you're speaking from experience (own the product) that's ever better.
  2. panic_mechanic
    panic_mechanic I've never done a mod!
    22 Nov 2009
    Ooh, interesting. I am after the same thing and is leaning towards a Dell Latitude E6420 14''. I don't own one yet but it looks like it is the best of the rest out there.
    I'm going to keep an eye on this to see what our most knowledgeable bit-tech mates recommend. :cooldude:
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I would think 14" or 15" would be the right size for you - any bigger would be difficult to carry around and any smaller wouldn't be a good desktop replacement.
    Sorry I can't point you in the direction of a specific model though! :)
  4. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    I've spent weeks researching this and finally purchased one last thursday. Out of everything out there, in the end I decided one built to my specifications from this company would be my best option. They don't seem to cut corners when it comes to performance, and being able to choose from several components was brilliant, cant wait for it to arrive (GS170...i7 quad, 8gb ram, 2gb video, 500gb hybrid drive, full HD screen)
    http://www.kobaltcomputers.co.uk/index.html
  5. Ploo
    1 Oct 2009
    Thanks, I've been looking at the Dell Latitudes and they do seem quite nice. Looking for more input.
  6. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Thinkpad.
  7. Ploo
    1 Oct 2009
  8. HandMadeAndroid
    18 Feb 2005
    Just ordered this:
    gs170
    Chassis - :: Kobalt GS170 17.3\' with switchable Optimus Technology utilising Intel GMA HD graphics
    Screen - :: 17.3\' 1920x1080 Full HD Matt LED Backlit NTSC 72%
    Processor - :: Intel® Core i7-2630QM Quad Core with HT 2.0-2.9GHz 6MB Cache 45W
    Video Card - :: NVIDIA® GeForce® GT 555M 2GB GDDR3 DX11 144 CUDA Cores
    Memory 1 - :: 8GB DDR3 1333Mhz CAS9 2x 4GB DIMMs
    Hard Drive - :: 120GB Intel 510 series SSD
    Optical Device 1/ 2nd HDD - :: 500GB 7,200RPM HDD
    Operating system 1 - :: No Operating System Required - £75 Cash Back after purchase!
    WIFI - :: Intel 6300 Ultimate-N WIFI module
    9 in 1 card reader - :: 9 in 1 card reader
    Keyboard - :: English UK
    Soundcard - :: Integrated High Definition Audio
    Power Cable - :: UK
    From http://www.kobaltcomputers.co.uk
    I had the same problem trying to find a decent machine that didn't cut corners.:waah:
  9. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    I cannot remember exactly but i think you get less support/warranty buying business over the retail laptops as they expect "bussiness" i would guess to take out support cover or may have there own IT staff etc...and you would likely miss out on retail packaging/discs etc, someone may correct me however as i have no actual experience buying there business laptops but just seem to remember reading something similar to above before.
    Dells are good for price, but can be a mixed bag on if you get a good one that lasts for years or one that you keep having to send back, its because they are fairly big they produce alot of them.
