Notebooks Looking for a laptop
Discussion in 'Hardware' started by 4pple, 13 Oct 2005.
  1. 4pple
    4pple What's a Dremel?
    12 Feb 2005
    Hey guys, I'm looking for a laptop for college. I will spend $1400 MAX on the laptop, and I'm looking for something that's really good performance wise, and decent looking. (No tacky alienwares :S) Any suggestions are welcome.
    Thanks a lot.
    -4pp
  2. ICDragon
    ICDragon What's a Dremel?
    25 Jul 2004
    I would probably look for a used laptop, depending on your needs. If you simply need it for the basics then there are plenty of good places to find decent cheap laptops (under $1000). If you want to game at all then you will be looking a little harder, try discountlaptops.com
  3. guy
    guy What's a Dremel?
    20 May 2004
    with just a quick search on newegg, these caught my eye.
    http://www.newegg.com/Product/Product.asp?Item=N82E16834114150
    http://www.newegg.com/Product/Product.asp?Item=N82E16834224028
    http://www.newegg.com/Product/Product.asp?Item=N82E16834115196
    One thing to keep in mind is size, i went with something smaller because i knew i would be traveling with it quite often so choose according to what you're going to be doing. Also think about the components you know and like.
    Some things to really look for are:
    CPU: AMD Turion 64 or Intel Pentium M
    Memory: at least 512mb
    HD: size is up to you, but 5400 rpm is definetly dominating over 4200 rpm.
    Video: 64mb dedicated preferable (i regret going with shared)
    Also keep battery life in mind, the more powerful and the larger the screen the faster it will eat though that battery.
