Cooling Looking for a LGA1155 CPU Cooler for about £15-20
Discussion in 'Hardware' started by Totoro, 6 Jul 2011.
  1. Totoro
    Totoro What's a Dremel?
    27 Feb 2011
    Hello, Im Looking for a LGA1155 CPU Cooler for about £15-20, & was thinking about the Arctic Cooling Freezer 7 Pro or the Gelid Tranquillo, but the review's on bit-tech dont say if they are compatible with Intel's 1155, will these fit ?
    Any help on the matter would be appreciated.
  2. KidMod-Southpaw
    28 Sep 2010
    They both fit 1155. How about the freezer 13?
  3. Totoro
    27 Feb 2011
    Thank you for the clarification, its just a bit confusing when it only says 1156,
    Is there much difference between the 7 & 13?
  4. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    the coolermaster hyper 212 is a pritty good cooler...
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    AFAIK anything that fits 1156 will fit 1155, Intel didn't change the hole spacing for the cooler.
  6. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Yeah 1156 spacings are the same, so it will fit.
    I would say in your price range the tranquillo would be a great buy
  7. Totoro
    27 Feb 2011
    Thank you for replying, as im a noob at DIY PC's I thought it would be best to ask first before I went out & brought one & found it did not fit.
    Question solved :)
  8. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Gelid Tranquillo?
  9. Totoro
    27 Feb 2011
  10. mars-bar-man
    17 Apr 2009
    I know it did... that's why I'm suggesting it.
  11. law99
    law99 Custom User Title
    24 Sep 2009
    I've enjoyed owning a arcitc freezer 7. It's really quiet.
  12. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Depends on the processor you are using.
    If you are using a standard non-K processor and won't be doing anything heavy you could get away with the stock cooler ok. Or use the freezer if wanting something 'prettier'.
    If you are planning on over clocking or doing heavy work loads, I would suggest spending an extra few pennies for the tranquillo, keeps my 2600k @ 4.7Ghz under 70 degrees with 24x7 running.
  13. Totoro
    27 Feb 2011
    I will be using a i3 1155, not overclocking it & with the hd3000 graphics.
    Build is here http://forums.bit-tech.net/showthread.php?t=212562 .
    Thank you for replying.
  14. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    In that case, it won't need anything more than the retail cooler in all honesty.
    If you will be using large photoshop files regularly you may want to consider getting 8Gb of ram with the extra £20 you have. You can get 2x4Gb dimms on offer for £50-£60 quite regularly on aria.co.uk with their deal of the day offers.
    I would also consider a different board too, you can get an MSI one for quite a few quid cheaper that would do exactly the same as the one you have currently if you can find it in stock:
    http://www.overclockers.co.uk/showproduct.php?prodid=MB-172-MS&groupid=701&catid=5&subcat=1907
    If you are only going for an i3 setup, I wouldn't worry about spending a hundred quid on a board, just go for something that will do the job. With the cash saved, you could maybe bump up the CPU...
    http://www.overclockers.co.uk/showproduct.php?prodid=CP-363-IN&groupid=701&catid=6&subcat=1275
  15. murraynt
    murraynt Modder
    6 Jun 2009
    Collermaster 212 Hyper plus
  16. Totoro
    27 Feb 2011
    thank you for the advice, thats the kind of thing I was looking for when I posted that thread.
    I will now take a look at the products you sugested.
    Also for the photography I try to get the picture as perfect as posible on the the camera, the main reason I use photoshop is for black & white as it is best to capture the picture in colour than convert it to b&w.
