Notebooks Looking for a new laptop need to understand more
Discussion in 'Hardware' started by veryevil, 30 Mar 2006.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, im looking for a new laptop but dont really know what to look for. I know next to nothing about lappies but was wondering if there were any guides or words of wisdom you may have.
    Things i would like to know:
    Processor speed: They all seem to be very low (1.6GHz) how does this compare with desktop comps.
    Athlon or pentium? whos the fav (I run athlons currently)
    Centrino, celeron (dont think so), Centrino Duo, Althon, Turion 64 and so on and so on
    Graphics cards also how do they compare with desktops?
    Any help would be great.
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    What do you want to use your laptop for?
    My main consideration was battery life since I never use my laptop at my desk etc. so I selected a lower speed processor and basic graphics giving me 4 hours on the basic single battery. If yours will be a desktop replacement then go for the powerful processors and graphics cards as battery life won't be as important (some only offer an hour...)
    I don't really notice any difference in the 1.5GHz processor that I have in the laptop and my desktop machines, but again it really depends on what you want to use it for...
    The Pentium Centrino and Celeron models are currently the best for low power consumption, and the Celeron really isn't that bad unless you're planning on using it for gaming.
  3. davethadawg
    davethadawg What's a Dremel?
    31 Mar 2006
    well basicaly theres 2 choices....
    Power Or Battery Life.. or portability vs stuckin the house(ness)
    i h8 2 say it but intel have got a better laptop system than AMD
    u get 4-5 hours out of a HP laptop with centrion tech where as the turion version of the laptop is about 2-3 :(
    how ever the Turion is one hell of alot faster than the centrino
    best speced laptops ive seen and sold are the Fujitsu Siemans stuff things like Athlon 64 M 4000+ with 100 gig HDD and 1GIG mem... not bad for a lappy
    Quality wise Sony n HP seem 2 be the most reliable... i very rarly c them back with hardware probs.... the sonys tend 2 use Intel centrinos rather than the turion :(
    where as HP will use anything lol
    but if ure looking for decent power vote AMD
    If u wanna watch 3 dvds in a row when on a plane grudgigly vote intel (god that hurt 2 say that)
    can ya tell i dispise Intel :p
    hope this helps a lil if ya have any other Q? just pm me n ill get 2 u asap
    oh PLEASE FOR THE LOVE OF GOD DONT BUY AN ACER !!!
  4. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, thanks for the help im looking for something that i can use for my main computer at uni as i dont wanna have my main comp at uni. Really I want something thats powerful and battery life isnt a main factor But i dont want a brick to carry around with.
    May be used with gentoo linux too so will need compiling power! (lots of the damn stuff :p)
    Would like gaming, something that would run UT2007 (when its out) but not full quality or anything just something that wont be to jerky (X700?)
    Cheers!
  5. SteveyG
    23 Nov 2002
    I know loads of people who have Acer Laptops and they've all said they were great and never had a problem with them. They're good value too.
  6. alastor
    alastor Minimodder
    6 Sep 2004
    I have an Acer with a Turion, it's very good. Although the Turion's do give slightly worse battery life, they can be easily undervolted to improve that. And they're cheaper too. Fairly sleek size and styling for a mid-powered machine as well, IMO.
    As for graphics, the X700 is probably the best compromise between performance and battery life. If you can, make sure you get a 128MB one as the extra 64MB does make quite a difference. You should be able to play UT2007, not at very high settings, but it should run.
  7. davethadawg
    31 Mar 2006
    im just looking at Acer in the shear returns sense i get the back to my store. in comparionson 2 any other brand they are the worst for returns.. that said u can pick up a good priced one. but if ure going down the acer route get on exstended cover on it least that means uve got a laptop for atleast 3-5 years.
    in that same note no Fujitsu-Seimans are the worst in the desktops we do there back with hardware faults all the time... shame realy cause there specs are amazing but the price is low.. guess that there useing cheapo parts...
  8. SteveyG
    23 Nov 2002
    What's the actual cause of the return with the Acers though, I bet it's rarely actually down to hardware failure or it falling to bits but rather the user causing the damage or installing things they shouldn't etc.
    What's the sales volume of the Acers compared to the others you are dealing with also?
  9. davethadawg
    31 Mar 2006
    Acers out sell HPz about 5 to 1 and the sony about the same and.. the only returns we do are hardware if its softwware we just sort it instore cause were nice that way lol fuji and tosh are poor sellers aswell though never shift a lot of them inless theres a good deal on them
  10. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, I think ive found the specs i want just need a laptop thats got them.
    Althlon Turion 64 ML (1.6~2.0)
    1 Gig ram
    > 40GB thats 5400rpm
    x700 ati gfx card
    Any ideas?
  11. alastor
    alastor Minimodder
    6 Sep 2004
    Acer 5020 series, same as mine. Though you would have to change the HDD, as most Acer's only have a 4200rpm drive. Acer Ferrari 4000 series, not sure on the hard disk though.
    After a brief look and memory refresher, I'm not sure anybody else other than Acer has an X700-Turion combination.
  12. veryevil
    veryevil Minimodder
    14 Aug 2005
    Cheers will look into them
  13. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    if you are in the uk, rockdirect.com have a good selection. evesham.com also, as well as obviously voodoopc.com
  14. riggs
    riggs ^_^
    22 Jul 2002
    My dad has an Acer 5020, and I own a 3022 - can't fault them tbh.
    Technoworld prices are pretty good (UK).
  15. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    Have you considered a MacBook Pro? Good power (Intel core duo) Good battery life (Intel core duo) widescreen lcd, up to 2 gb ram, dvd burner built in, wifi built in, bluetooth built in....
    $2000 isn't so bad for all of that and build quality is top notch.
  16. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    Not only that but you can install windows on a macbook pro. I am basically in the same dilemma, but i really want to see a core duo with a 7800 paired together or maybe a X2 4000+.
  17. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, thanks everyone i just caught up with this thread. Plans have changed im now thinking of waiting till about august and selling my main computer and my current laptop to get a really good lappy then for uni
    Cheers
