Portable Looking for a new phone
Discussion in 'Hardware' started by Anator, 20 Jul 2007.
  1. Anator
    Anator What's a Dremel?
    26 Feb 2004
    Hi all,
    My Samsung E330 and Ipaq are getting on a bit, and I would like to try and get a phone that replaces both.
    I want the phone to have all the latest phone features such a bluetooth, video calling, decent camera res etc, but also have the features of my pda - i.e full calender, GPS/sat nav and WiFi.
    I have been looking at a couple of Nokia's - in particular the N95 but have heard mixed reviews on it, some saying that they have had major problems with it. I'm also not sure if it will sync with Outlook to update my calender.
    Has anyone got any suggestions?
    Cheers
  2. fwalm
    fwalm What's a Dremel?
    4 Jan 2007
    if you go on a contract with orange get the nokia n95 which normally costs around 600 youll get for 90 or so on a 35 month contract with unlimited texts and calls and then you can get 8mb unlimited broadband for an extra fiver
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    If you don't really need GPS/WiFi, then Sony Ericsson K800i fits your specs perfectly.
  4. Anator
    26 Feb 2004
    I do need them im afraid if the phone is to replace my PDA.
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    N95 or the N80 then :)
  6. Valo
    Valo Minimodder
    11 Aug 2004
    nokia e90 imo is all you need :)
    also, don't worry about calendar/contacts, symbian based nokias sync with outlook beautifully :)
    alternatively you could try htc touch
  7. Anator
    26 Feb 2004
    Right just bought an N95 off ebay :)
