Looking for a strange power supply.
Discussion in 'Hardware' started by OtakuHawk, 1 Mar 2008.
  1. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    In my various musings, I find myself looking for a power supply with the following qualities:
    Input:
    12vdc
    OR
    120vac/240vac
    output:
    5V @ 12A
    3.3v @ 15A
    12V @ 10A
    It's for a mobile network/storage center, and I'd like to be able to get power anywhere, be it a few deep-cycle batteries, or a convenient wall plug and extension cable.
    I initially thought of just using an inverter, but 300 watt inverters are rather large an inefficient.
    I have seen a few laptop power bricks that can do this. can it be scaled upwards?
  2. Zytek_Fan
    Zytek_Fan The tortoise
    8 Feb 2008
    There are very small form factor power supplies. I remember seeing them on newegg, but I can't find them now.
  3. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    Your best bet is a -48V DC power supply (Commonly used by telcos) with a rectifier powering the system when you have AC. It'll be expensive, but it's probably your best option if your serious about it.
    Edit: Better yet: buy a UPS on ebay (many are sold without batteries/ dead batteries) and Hook it up to some external batteries with some 6awg cable. A bit of soldering and dremeling later and your done.
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    You may want to investigate CarPC websites.
