Modding Looking for a washer? Spacer?
Discussion in 'Modding' started by m0ng0lh0rde, 1 Sep 2005.
  1. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    Here's what I'm looking for. I'm not sure what to call these, and so have had no luck finding them in the forums, or on the web. Basically, these would be (preferably) anodized aluminum spacers/washers. Shaped sort of like a cone, and designed for countersunk screws. They'd be something like below:
    _____
    /_|_|_\
    Please forgive my poor ASCII art skills...
    The center portion is where the bolt would go through, and the top would be shaped to allow a counter-sunk bolt to sit flush.
    These would be around 3-4mm high, maybe about 4-5mm in diameter.
    Anyone know what to call these, and where I might find them?
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    i know exactly what those are, i forget what they are called, i had to pick up some of those for the resturant i work at just the other day at lowes, im pretty sure an equivilant store around you sells them, they are cheap, and really save time when when doing things, when used right, they often look better then if you had actually countersunk the hole
  3. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    at this site (link) they sell 'M3 finishing caps', is that what you're looking for?
    edit: look under 'general parts' and then 'fasteners'
  4. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    My dad is a carpenter so will probably know what it is, I'll ask him what it is when he gets back from work!
  5. Nexxo
    23 Oct 2001
  6. m0ng0lh0rde
    5 Jun 2004
    OOOO!
    Pretty much exactly what I'm looking for!
    Made the mistake of e-mailing a company a request for quote on these things, anodized blue, 50 count order....
    They wanted $6.70/ea(!!) and $105 plating charge(!!!!)
    Next question:
    How do you think it will look using these finishing washers, and flat head socket screws, to hold a side panel window on?
    Case is a CoolerMaster Stacker. I was looking at possibly going with black anodized, but blue is good too....
  7. Nexxo
    23 Oct 2001
    I think you need countersunk screws with these for a cleaner finish (it's how I plan to do my window). I'm sure that if you Google around a bit you can get both in black, in the US. Ask Scopedog --he has a good US scource for fasteners.
  8. m0ng0lh0rde
    5 Jun 2004
    Yeah, the flat head socket screws are countersunk. I thought about using dome-head screws, but they don't seem to come in countersunk, and in which case, I could just use the dome-heads by themselves...
  9. Nexxo
    23 Oct 2001
    Try looking for "fairing bolts". They often have a suitable shape.
  10. m0ng0lh0rde
    5 Jun 2004
    **PERFECT**
    Now to find a US supplier of these things, without having to wander around motorcycle shops....
    All the online places with these bolts individually are in the UK....
  11. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I use these 'countersunk panel washers'.
    They're in anodised aluminium, loads of colours and fit countersunk M5 bolts. Sorry, UK link again, BSR Aerotek. Perhaps they might ship to the states?
  12. m0ng0lh0rde
    5 Jun 2004
    Nope, unfortunately, they don't ship to the US....
    And they had what I was looking for....
    :sigh:
  13. jokkos
    10 May 2005
    hmm they seem to ship to the US
    'Overseas carriage charges: These will generally be 2-4 times the cost of UK carriage. The further away you are, and the more off the carriers "beaten track" then the costlier the service. We do not aim to make a profit from our carriage, however we can not afford to make a loss either. Eg : Europe is double UK carriage, USA and Far East is quadruple.
  14. m0ng0lh0rde
    5 Jun 2004
    Seems like I'd need to phone in the order, as their online order page spits up "No carrier to selected location" when I try to move past shipping address...
    I've found what I'm looking for though at an RC Helicopter place that was linked higher up in the thread. M3 sized....
    Just took a tape measure to the button heads holding the side grill on, and found they're 1/4" (about 6.25mm). Maybe I will call these guys and see what they charge.
