Other Looking for cable sleeves
Discussion in 'General' started by silk186, 10 May 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I'm looking at making my livingroom look less rubish. I have a mess of cables under my TV, running to the speakers and my PC. I also have a bundle of cables running from my computer on the dinning table to the tower behind me.
    The TV was is 1.4m and the computer run is similar in length. I would want sleeves that are longer than 1m to make things look better. Has anyone found anything decent? It seems most products I'm finding are "19.7 inch Cable Organizer Sleeve".
  2. legoman
    legoman breaker of things
    28 Feb 2010
    What type you after? You can get spiral wrap by the meter usually online.
  3. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
  4. silk186
    silk186 Derp
    1 Dec 2014
    That's one option, but I'm not sure it will look the best below the TV in my living room. If I owned the place I would run a conduit through the way and wire an additional wall socket.
    Is that the most common solution?
  5. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    How are you with a knitting corker? Custom cosy cables...
    Your options
    • split loom
    • split warp
    • spiral warp
    • surface duct
      • Wall mount
      • floor runner
    I'm not sure what is available in your region but you can refer to cableorganizer.com for reference.
    silk186 likes this.
  6. Vault-Tec
    30 Aug 2015
  7. silk186
    silk186 Derp
    1 Dec 2014
    I thought those are for mechanical keyboard enthusiasts ???
    This list would have taken me days to find these names. Ikea's naming for split loom is RABALDER.
    This is a handy tool that I just discovered:
    I can't really go wrong with a "2 Metre Cable Tidy Kit" on eBay for £3.39
  8. Guest-44638
    Guest-44638 Guest
  9. silk186
    silk186 Derp
    1 Dec 2014
    Yes, but I don't need 25m.
  10. Dr. Coin
    13 Sep 2013
    Yet.
  11. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    silk186 likes this.
  12. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I can't find a link, but I used some neoprene velcro cable wrap stuff. I've used it all over the place, I quite like it. I think the brand started with an M..
  13. saspro
    saspro IT monkey
    23 Apr 2009
  14. liratheal
    20 Nov 2005
    Similar - But not quite.
    It's actually really bugging me as I want some more, but the main body of the wrap attaches to the velcro, so you can trim it in two dimensions, as well as being super thin so there's not this bulky cable snake. I know I bought it on Amazon, but that order seems to have disappeared..
    The closest I've found is one from some brand called "Melca" but it looks a bit **** compared to what I've used so far.
  15. Dr. Coin
    13 Sep 2013
    The tool is a nice to have for the loom/wraps, but one can install without it.
  16. silk186
    silk186 Derp
    1 Dec 2014
    neoprene velcro - looks great but only seems to come in shorter lengths for Desktop under the desk.
    The split loom arrived and it looks good. Seems 15mm is only enough for a few runs and I will need some 25mm for the run below my TV.
    The plastic fabric wrap looks good as well but it looks to be all sold out and none on eBay.
    After rotating my desktop to show off the TG window and RGB fans, I need to replace multiple USB runs with longer cables, 5m is not cheap so I might wait until my next China visit and order a handful: USB 3, USB C, HDMI, DP.
