I've seen them around, they look a bit like MDK's grille, but they have some kind of small logo on it. They are also sold for 2 fans, and even 3 fans (rectangular versions that is) Yes, I did use search, I checked other forums as well... Who can help me out here?
the search must be b0rked then, because I posted a reply to someone asking about the heatkiller grills the other day
nah, it's probably just my 1337 s34rching sk33lz Thnx Kong, the Heatkiller grilles were the grilles I was looking for indeed!
anywhere where you can use them of course... Most likely on watercooling radiators and things like that
I have the 120x3 on my thermochill 120.3 with titan alu fans Although I suspect they would look good replacing the grill on the front of a lian or coolermaster case
I have a Compaq ProSignia 3080 right here, and I don't have a doubt that they would look good on that too!! The standard front of the case is just not good enough for fitting a fan, it would be wrong to put a fan there, if you could also use a grille like that on the side of the case...
i will be fingers crossed Chruning out a load of my grills this week they are similar too the heatkiller grills but not hte same. I'll see how they go, Kong will be getting one as soon as they are made along with Coolmiester so when there done i'll get them to review them or somin. Keep and eye out dude
