Modding looking for large heatsink material
Discussion in 'Modding' started by mrplow, 20 Jan 2003.
  1. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    im looking for a big 'sheet of heatsink' if you will...
    something with fairly low profile fins, and a large surface area. i cant think where such a thing would come from.
    e.g. 1' square, with 1/4" fins?
    any ideas?
  2. Morphine
    Morphine weeee!
    23 Feb 2002
    ive seen lots of stuff like that go on ebay for VERY cheap
  3. Dark_Blender
    Dark_Blender What's a Dremel?
    3 Jan 2003
    LOL The old Pentium 2 heatsink. Those beasts ruled LOL :rock: :rock: :rock:
  4. mrplow
    5 Sep 2001
    thx morphine i hadnt really thought of looking
    dark_blender: a bit bigger than that mate, and a helluva lot lower profile.
  5. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Are the ones I have no good? (There's plenty more of the type you won)
  6. Madyeti
    Madyeti Supermodder & sig shrinking victim
    1 Dec 2002
    Let me preface this by saying that opening up a monitor is risky work if you don't know if the huge transformer/capacitors have been discharged. BE CAREFUL!
    If your looking for heatsinks, older monitors have a lot of them...but, they are small. I "rescued" a dead monitor from the dump and got a lot of heatsinks out of it. The larger ones are about 2" x 2.5", but they have small grooves on the sides so that theoretically you could run a small metal rod to connect lots of them together. Hope this Helps, ~Davy
  7. mrplow
    5 Sep 2001
    brad my good man when i said low profile, i meant to say lowwwwwwwwwwwwwwwwwwww profile.
    really thin.
    if anyone has a thermaltake gf4 cooler, there are 2 types of ramsinks... some fairly big ones, and some that are almost flat. i want a sheet like the almost flat ones.
    brad, ur heatsink:
    what i want:
    ¦¦¦¦¦¦ <- and thats 2 layers! ;)
    mmm ascii art expert
    this is better:
  8. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    just find some and cut them down to the right length.
  9. mrplow
    5 Sep 2001
