Education Looking for material advice.
Discussion in 'General' started by Kronos, 30 Jul 2015.
  1. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    My good lady has to sit whilst showering nowadays so I have bought a seat and also another caddy for shampoos ETC. But this caddy http://www.amazon.co.uk/Luxxur-Supe...&qid=1438271656&sr=1-26&keywords=Shower+caddy Is actually pretty rubbish of having things standing upright in it.
    So am looking to cover the bottom of the caddy with either something solid with loads or holes or something soft but porous. Usually pretty good at house related mods but this has me beat at the moment. I do have a bit of acrylic but cutting it will be an issue.
    Any suggestions. Ideally something easily worked be it solid or soft.
  2. wst
    wst Active Member
    30 Aug 2009
    How about a cheap bathroom sponge? Slice it with a bread knife to the desired thickness and shape.
  3. Kronos
    6 Nov 2009
    Would that support these bottles which are now for the most part very slender with not much of a footprint? Worth a try though as sponges I have a plenty.
  4. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    I wouldn't use a sponge. After the shower the sponge will remain saturated, and it will promote mildew growth inside all the little pores. If you're looking for something solid to place bottles, you might try lining the bottom with a small piece of plastic that is designed for wet environments - such as a cutting board.
  5. Kronos
    6 Nov 2009
    I also have a chopping board, I assume that is what you meant, going spare as she has just had me buy a granite board in preparation for the new kitchen being installed next month.
  6. legoman
    legoman breaker of things
    28 Feb 2010
  7. Kronos
    6 Nov 2009
    I have a bit of this but it is not really going to be stiff enough. By the way the stuff is rubbish for stopping mats sliding on carpets.
  8. asura
    asura jack of all trades
    22 Apr 2009
    Some thick-ish neoprene?
  9. theshadow2001
    3 May 2012
  10. Tomhyde1986
    Tomhyde1986 New Member
    25 Jul 2009
    I like the chopping board trimmed down the right size idea. You can then always pop it out every now and then and give it a soak in bleach to keep it clean.
    A hacksaw would cut it easily enough.
  11. Kronos
    6 Nov 2009
    I think I'll go raking about my local pound shop and get a selection of products to attempt to make something useful.
    Thanks all for your suggestions.
  12. ElThomsono
    ElThomsono Well-Known Member
    18 Mar 2005
    Why do I keep reading this thread title as "Looking for marital advice"?
    Chopping board sounds good but they're pretty slippery, if it's not perfectly level I think you might have bother.
  13. Kronos
    6 Nov 2009
    Got 4 large vinyl tiles from the pound shop and a small chopping board cut them to size. Chucked the chopping board bit away because I was not happy with the cut. Used the tile on it's own.sorted.
