Electronics Looking for Software or Hardware that will..
Discussion in 'Modding' started by Soulmage, 21 Feb 2006.
  1. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    I am looking for a way to use 1 keyboard for 3 computers…. I
    have 3 desktops and 3 monitors… What I am trying to do is have the
    same input from 1 keyboard do the same thing on all 3 desktops, all at
    the same time.(Maybe some sort of USB Y adapter)
    Example: I open up WORD on all 3 computers, and type a letter… What
    happens is all 3 computers will type the same letter at the same
    time.(using 1 keyboard)
    I have looked into KVM switches, but this only will allow you to
    switch between 1 computer at a time.
    Additionally, is there a way to use 2 keyboards (USB) on the same
    system (second keyboard would act like an extra 108 function keys
    instead of a standard keyboard.)… Software controlled? (I know there
    are 180 key set panels out there, but at $320+ I would rather rig up a
    $10 keyboard and label the keys myself with white out and magic marker)
  2. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    No one has any ideas?
  3. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    nope, just do a 3-way hardwire of a USB or PS2 cable. only supply power from one of the PCs, and just put dummy loads across the others.
    IDK about the independant function key thing though. try searching through sourceforge or wade through google.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    It'd be easy to build one for PS2 using a PIC, but USB I have no idea about.
  5. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    you could use MultiDesk by stardock...that might help
  6. Ener
    Ener What's a Dremel?
    17 Oct 2005
    you could network them then just copy it over lol
  7. exavier412
    exavier412 What's a Dremel?
    15 Jan 2004
    yeah. i'm curious to know why you would want to do that.
  8. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    For a game that i play. i have mutiple accounts. 1 acct has a seer class, and 3 others are a mage classes. I would like to be able to have the mage classes all cast at the exact same time.
  9. NoMercy
    NoMercy What's a Dremel?
    23 Nov 2004
    You might be able to modify something like synergy2 to do it, but isn't that cheating anyway?
  10. knyghtryda
    knyghtryda What's a Dremel?
    2 Jan 2006
    synergy has problems working with games, cuz it either doesn't work or it defocuses the game. IF you were running all three games windowed, then it would work however. just earch synergy. I'm also doubting the morality of doing this however.... can't you just be content and get some friends?
  11. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    I can vouch for Synergy not being very game friendly. Some games would work just fine, mainly RTSes and RPGs. FPSes performed miserably, as the sensitivty in-game (no matter what adjustments you did) was so high it was impossible to do anything.
  12. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    The trouble with this setup would be that any decent game would have built-in slight randomness to prevent this, so you had to slightly adjust your player all the time.
  13. freemc
    freemc What's a Dremel?
    20 Feb 2006
    Using 2 keyboards on 1 pc isn't really a problem. You could use a PS2 splitter. I don't know how you have to configure it to work properly though...
  14. Faind
    Faind What's a Dremel?
    30 Jan 2006
  15. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Sadly what i was trying to do was figure out how this guy was doing what he does.
    http://www.teamwizzy.com
    Watch the videos to get a better idea.
    Basically he has it setup some way so that he can cast the same spell on 5 different accounts at the same time. As well as controlling a 6th toon.
    Yeah so i was bored, Sue me :)
    And no, it's not cheating, at least i wouldn't think so, this guy has been doing this for quite some time.
  16. Macaba
    Macaba What's a Dremel?
    4 Mar 2006
    "It'd be easy to build one for PS2 using a PIC"
    I'm not so sure. I've yet to get a PIC to send keyboard codes successfully. If some sort of external switching was done, then ok.
  17. freemc
    20 Feb 2006
    remote desktop maybe?
  18. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    how can remote desktop allow you to control 6 computers at the exact same time?
  19. freemc
    20 Feb 2006
    Not sure about it, since the setup in the link doesn't use any kvm switches or anything, it would seem like the most logic solution is some kind of remote desktop thingie. But I don't know if it is possible I don't have much experience with remote desktop applications.
  20. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
