looking for some software for the arctic liquid freezer ii 360
Discussion in 'Watercooling' started by kuroidoragon, 12 Aug 2023.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    Tomorrow I should be getting the
    https://www.amazon.co.uk/ARCTIC-Liq...prefix=ARCTIC+Liquid+Freezer+II,aps,78&sr=8-4
    from a quick google search I found out this supposedly doesn't come with any software
    is there any simple & easy to use software for it someone can suggest that will let me make & save some fan curves & control the pump ?
    please bear in mind I am slow & a bit thick so it does need to be simple software nothing hard to setup
  2. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    There's only a single pwm connector on it to connect to the board, so it doesn't really need much software.
    For setting a specific fan curve though, you can't go wrong with fancontrol
    Big Elf and kuroidoragon like this.
  3. kuroidoragon
    14 Oct 2012
    okay cool that defo work with the mentioned cooler ?
  4. The_Crapman
    5 Dec 2011
    Yeh it will work fine. Just plug the connector from the cooler into one of the fan headers on the motherboard.
  5. VictorianBloke
    31 Oct 2007
    It's worth being aware there was a previous recall on the freezer ii's. There was a batch made with faulty gaskets. Newer units made/shipped after they identified the fault should have a little round QC sticker on them.
    You can check what to look for, and the details, here, on the off chance it's old stock. That was over a year ago though, so you should be fine.
  6. kuroidoragon
    14 Oct 2012
    It is all in & working fine it is the same one as what my dad has & he has had it a lot longer then me no complaints here
    if we actually get anymore hot weather at least I am better prepared for it now & no more fan struggling noises
    VictorianBloke likes this.
