Modding Looking for Tubing/Coolant Advice
Discussion in 'Modding' started by janger, 18 Mar 2009.
  1. janger
    janger What's a Dremel?
    2 Apr 2007
    Im trying to recreate the color of the coolant/tubing in this project log.
    I'm completely replacing the tubing in my system, its suseptable to caving in,and I'm looking for something more durable, and possibly a silicon material to give this milky effect to the coolant. Any advice would be appreciated.
  2. stuartwood89
    20 Aug 2008
    I don't know myself, but I think the builder of this system is on this forum. I'll have a look for his username so you can PM him.
    EDIT: I'm sure it's Pookeyhead, send him a PM. I would send you a link to his project log, but the only like I can find is broken. I hope this helps.
  3. talladega
    talladega I'm Squidward
    18 Aug 2007
    I seen this pic in a thread about purple LEDs about a month back.
    I think to get the effect he's using UV lights and purple LEDs with UV blue coolant. I may be wrong though.
  4. Guest-23315
    Guest-23315 Guest
    ^^ That was Pookeyheads PC-70..
    IIRC, its just some 12" UV CCFL's and some distilled water with UV blue revelaing dye in there.
  5. stuartwood89
    20 Aug 2008
    Yeah that was my thread. It's long dead though :(
    I remember looking for this log a while ago. I think he used pink LEDs and purple coolant, with some UV cathodes/LEDs to highlight parts. I can't remember if the coolant was UV reactive though.
  6. janger
    2 Apr 2007
    thanks for the feedback, ill post my final product soon. Here's a sample, its my first btw. Any suggestions of additions or comments would be great. I'm completely replacing the tubing that's installed and have a lot more work and ideas to follow up with.
    Core2 Quad, Liquid cooled, 3.6Ghz
    2x150GB Velociraptor Hard-Drives Raid 0
    6Gigs DDR2 PC6400 Gskill
    4870 1GB GDDR5 Liquid Cooled
    1000W Antec
    Asus Maximus Formula 2 Motherboard
