Windows Looking for
Discussion in 'Software' started by Melov, 21 Jul 2004.
  1. Melov
    Melov What's a Dremel?
    30 Apr 2003
    A program that will allow me to end a program by pressing a certain key that I set.
    For example:
    I'm running a game called game.exe
    I want to set it so if I were to hit F12 it would end game.exe if I needed to quit it.
    Any suggestions?
  2. exavier412
    exavier412 What's a Dremel?
    15 Jan 2004
    alt+f4 usually closes whatever the focus is on
  3. octabot
    octabot What's a Dremel?
    29 Jul 2004
    Sounds like you want a panic button...
    Alt+F4 should quit just about any program.
    I often use the (windows), (u), (s) combo which will put the computer to sleep in less than 3 seconds.
    Octa
