Education Looking to create space
Discussion in 'General' started by Kronos, 6 Mar 2018.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    In my man cave I need to think about layout. (See image)
    I would like to remove the desk on the left and in some way relocate my secondary PC which is mall as it is housed in a Silverstone Sugo but does have a 27" monitor attached which I have no wish to change for a smaller one.
    My initial thought is to bung my main PC in something like this https://www.amazon.co.uk/Allcam-Com...pID=31sreAqrzbL&preST=_SY300_QL70_&dpSrc=srch and sticking it under the big desk. Then moving the 32" monitor along to the right though I suspect that will not give me enough room for the 27" monitor.
    Reason for more space ned is VR and the impending arrival of the Rift, but that aside I have felt a bit cramped for a while.
    Is there anything around that I can fix to the underside of the big desk which will accommodate a small PC.
    Any other suggestions?
  2. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    My pc lives between my desk and a storage unit, so is not easy to get at. To get round that and lift it up a bit, I made a wheeled platform so it is nice and easy to get out. Something similar may work for you.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have bought a wheeled platform and I am currently moving with a little bit of modding the slide out keyboard tray on the defunct PC desk unit to fit underneath my main desk and with a Ergotron monitor arm I discovered in a long buried box it is all coming together quite neatly.
    Mr_Mistoffelees likes this.
  4. Mister_Tad
    27 Dec 2002
    I've found time and time again, the best way to make space is to get rid of some of the stuff taking it up. There's no substitute for a good clear-out.
    Get the monitors attached to the wall or on a dual screen stand, clear out half of the rest of the stuff, then get rid of the excess furniture. Change the desk for something else with more integrated storage for the PC.
    Or get an ultra-wide and forget dual-screen.
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    One of those nifty under-the-desk PC hangers works great for keeping it off of the floor without taking up desk space.
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Got a trolly thing coming for the under desk PC but this is what I managed to put together yesterday and today even down to modding a pull out tray for a keyboard.
    Arboreal likes this.
  7. yupson
    yupson What's a Dremel?
    31 Jan 2018
    Looks much better now.
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    And I have oodles of space for VR fun.
