Modding Looks ok so far....
Discussion in 'Modding' started by conteoAMD, 19 Oct 2006.
  1. conteoAMD
    conteoAMD What's a Dremel?
    15 Oct 2006
    Hey guys, I'm new, and after acquiring a server case last week I thought I need to sign up here.
    So here it is so far, im going to paint the sides and top blue tomorrow. And then cut a splat out as a window and use green acrylic as a windows, and then fill the inside with green neons and blue fans. whats you guys fink so far?
    PIC >>>> http://www.speedyshare.com/446256263.html
  2. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Sounds just like any other mod. It needs something to make it stand out. But your server case won't be ATX either so you will need to sort that out.
  3. conteoAMD
    15 Oct 2006
    why would I want it to be ATX?
  4. Frogmonster
    Frogmonster What's a Dremel?
    14 Oct 2006
    live animals... You need to make a hamster cage out of it. :thumb:
    I do have to agree. It just depends if your looking to impress yourself or impress others.
    I'll never be able to mod like G69T's Dark Blade. http://forums.bit-tech.net/showthread.php?t=76374
    I'm just modding my laptop just for personal satification. And to see what i can do with a limited budjet and time.
    I'm curious to hear if you have any other ideas. Defenatly post how your progress goes. G-Luck. :dremel:
  5. bumfluff
    18 Aug 2006
    Ok so you aren't putting a new system in it.
    Just coem up with some ides that will make it different. Your whole colour scheme sounds really good, it just need that something that will give it the wow factor. Not that it won't look good its just if you want your mod to be memorable then you just need to add something that is slightly different no matter how small.
  6. Frogmonster
    14 Oct 2006
    hamsters! yah... Lots of cute hamsters! :D
  7. conteoAMD
    15 Oct 2006
    Any Ideas?
  8. bumfluff
    18 Aug 2006
    If you think of a theme then that makes it a lot easier of what you could do to make your mod special.
