Case Mod - Complete LORD HALLY CHROMA (RGB MADNESS)
Discussion in 'Project Logs' started by zulboy45, 19 May 2018.
  1. zulboy45
    zulboy45 What's a Dremel?
    17 May 2018
    Hi for this work log i dont have picture. but i put all in a video
    check out below
    most part of hue led i used addressable LED ws2812b and attiny85 or aduino nano. the got pretty big sample and library on internet.
    Final pic
    The led behind the screen is sync to real time according to screen color.
  2. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    How did you achieve that?
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    MLyons likes this.
  4. Cheapskate
    13 May 2007
    JJ Abrams approved.
  5. kim
    kim hardware addict
    10 Jan 2016
    great work on lighting effects :thumb:
  6. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    Search for Ambilight projects. Some RGB addressable leds, arduino and hdmi grabber usually. Not hard to do and it looks awesome.
    Impatience and MLyons like this.
  7. zulboy45
    17 May 2018
    CORRECT !! other word is adalight. i use USB sending signal from pc to arduino. so no need complex hdmi processing like rasbery pi
    Impatience likes this.
  8. Impatience
    Impatience Minimodder
    6 Apr 2014
    That screen illumination is awesome!
  9. zulboy45
    17 May 2018
    Never fail to impress me
