Photos Lord of the Flies
Discussion in 'Photography, Art & Design' started by Tomm, 19 Aug 2006.
  1. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    First pic on here, be kind.
    Back-to-front lens picture of a fly.
    I stopped down to f/8 to get the awesome depth of field you can see - otherwise it's paper thin.
    ISO 500 (Just because I can now :D )
    0.3s with mirror lockup
  2. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    wow! how the hell did you manage that without the fly flying away and the merest hint of you coming towards him?
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    :D Very nice
  4. Tomm
    12 Apr 2004
    Haha, if I told you, you wouldn't be impressed at all.
  5. olv
    olv he's so bright
    23 Sep 2002
    it's dead?
    do you have a reverse lens mount or is it hand held? i found hand holding stupidly hard.
  6. kenco_uk
    28 Nov 2003
    You cropped out the dog turd?
  7. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    it's paper thin!?!
    (did I get it?)
  8. Tomm
    12 Apr 2004
    Yeah, it's dead I'm afraid. The end of the lens was less than 1cm away from the fly, and with a depth of field of WAY less than 1mm, there's no chance of getting a decent shot that close-up on anything that moves. I don't have a reverse mount (might buy one though), but I did do a bit of a ghetto mod with string to attach the lens to the camera without having to hold it.
    And no, it wasn't on a turd. It was actually on a BLACK book, and I cropped nothing. I can't quite work out why the background is, well, white.
  9. woodshop
    woodshop UnSeenly
    14 Oct 2003
    Fly paper :)
  10. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    The book is likely white due to reflection of light.
    It is white enough that it is just washed out.
  11. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    If you catch a fly, or other flying insect, you can put it in the freezer for a short period of time and it will go into a hibernation type state. It should be asleep long enough to take a picture, once it warms up it will be fine.
  12. Firehed
    15 Feb 2004
    Tell that to the fly. I'm quite sure he'll find it most disagreeable.
    That said, it's a cool idea. Pun very much intended.
    Anyways, nice photo. I've always been into those crazy-close macros. And unlike some hornet that someone did in macro once, it didn't quite freak me out :worried:
  13. scq
    scq What's a Dremel?
    4 Mar 2005
    Maybe it's a combination of reflected light, as well as your camera metering to expose for a dark fly, hence blowing out and overexposing the background?
    Seeing this, I too should grab a reverse lens mount. I wonder what would happen if I tried to do it with a long focal lenth.
    Reverse 200mm anyone?
  14. Tomm
    12 Apr 2004
    I tried my 55-200 on reverse and it did nothing at all. Couldn't get anything to show up whatsoever. Guess it's just certain lenses that work - A reason to keep hold of the Canon kit lens, anyway.
    You wouldn't want 200mm anyway - the magnification works in reverse so wider lens backwards = more magnification. Although I think for that picture, the lens
    (18-55) was at about 35mm ish - Any wider and you get too close and have zero DOF.
    EDIT: It was taken in manual mode and I know why it was like that really - the book was shiny with light being reflected directly into the camera and the shallow depth of field meant that any detail was completely removed.
  15. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    I knew it!! :rock:
  16. Dark_Master_Dragon
    Dark_Master_Dragon Beware of my lair!!!
    22 Jan 2009
