I have Acer Aspire 5720Z and old hd failed, i replaced and reinstalled Vista. The problem is that the num lock and hdd indicator lights no longer work. I cannot find out where i can find drivers or settings to enable them. Help plz. Ta Neil
Start > Control panel > device manager, I imagine the keyboard driver will have the yellow warning symbol next to it- you can select update driver online which will install drivers from microsoft ( may or maynot work perfectly ), or you can go to the Acer website and should be able to find your model of laptop & downloads for it without too much hassle. Check the rest of the devices to see if any other items are flagged and update drivers as required...
