Modding loudness exposed
Discussion in 'Modding' started by bee2643, 2 Apr 2002.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    i finally figured out what the loud humm was comming from, my damn burner has this small fan in it the size of a toonie, is it possible to take this fan out without having the burner mess up, because its really loud:eeek:
  2. Cool Hand
    Cool Hand King of the park
    21 Nov 2001
    hey fellow canuck.....not many here are going to know what that is...let realy confuse them and say its bigger than a loonie, but smaller than a toonie....
  3. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    aint a loonie a peice of canadian currency?
    hehe
  4. bee2643
    7 Mar 2002
    allright allright
    the fan is 2cm in diameter :p
  5. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    Strap on a delta!
  6. brutal
    brutal What's a Dremel?
    7 Nov 2001
    delta makes a 200cfm 120mm fan that would definately drown out the sound of that 2cm one :D
  7. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    fans r normally there for a reason so wack an extra temp probe inthe drice and see how hot it gets if it aint that hot remove the fan and try again then see if it gets much hotter
    thats what id do ne ways
  8. Fly
    Fly inter arma silent leges
    31 Aug 2001
    I think it's a loony cos it has a picture of a Bird called the Loon or something on it ( the Canadian Coin that it).
  9. Digitalblueshift
    12 Feb 2002
    The loonie is a one dollar coin, brass colour and just larger than a quarter, and a bit smaller than a half pound. The toonie is just larger than that, two colors and You used to be able to pop the middle out of it.
    Loonie on top, toonie below[​IMG]
  10. Seth
    Seth What's a Dremel?
    14 Mar 2002
    okay i have never heard our money having to be explained lol..
    what would really mess people up is the fact we have 2 different looking 10 dollar bills and 2 different 5 dollar bills
    they are changing them over right now and you get both in your wallet all the time lol
  11. Digitalblueshift
    12 Feb 2002
    Its better now, if you know braille you are set (dot 3,4,5,6 low e) Heres the $5 you wanted.
  12. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    lol our £2 coins are like that, you can pop the middle out of them, makes them worthless tho :miffed:
  13. bee2643
    7 Mar 2002
    look at the topic ppl
    IT DOESNT SAY CURRANCY :p
    anyways, the thing prolly doesnt pump more than 1 quarter cfm, serious, the blades on it are almost verticle, prolly around 1200-1400rpm, and because its so old its got this whirring sound to it now, almost like your sticking something into the blades of a fan, only theres nothing sticking in the fan
    i think i will just remove the mofo
