My friend and I have been looking at the Allwinner A10 as a possible HTPC replacement. It runs Android 4.0 ICS, has a 1.5Ghz ARM CPU, a Mali 400 GPU, and 512MB of RAM. However, it only has wireless (booo). Not only that but, buying something pre-made just isn’t the Bit Tech way is it now? I was wondering, is there an equally low cost alternative that I could build myself? I’ll fab the case out of Acryllic, but what about the rest? Must haves Smooth 1080p playback Network (Ethernet) port Would be Nice: XBMC Compatible Any recommendations or ideas?
Mine is due in 2 weeks. Did you register interest? Stock should be arriving soon and in large numbers hopefully
Alternatively then, What kind of TV is it, and what kind of content do you watch? an Apple TV 2 might be the suitor for you?
Yup, a simple jailbreak, then there's an installer you can run. I would have done this ages ago, but ATV2 is limited to 720p... That's it's only downside.
Planning to use my Rapsberry as a learning unit for XBMC whilst I have a stable working build in use. Simple and cheap option
DancingBear84 just sorted me out with a spare Raspberry PI order code he had! What an absolute legend! Cheers matey! +rep!
No worries. It seems fair to me as I wasn't going to use it. And before anyone else asks, no, I don't have any more. I've not been called a legend for a while.
