Cooling Low profile cpu coolers
Discussion in 'Hardware' started by icutebluezone, 5 Jan 2009.
  1. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Hi need sum advice on low profile cpu coolers.
    Going to be going on to a pcu like a Intel Q6600 or Q9550 socket 775.
    Max high i can have is 82mm high.
    Coolers i have found so far:
    Silverstone SST-NT06-LITE, CPU Cooler, Black/Silver
    COOLER MASTER Geminii S RR-CCH-PBJ1-GP
    Cooler Master GeminII, CPU Cooler, 175mm, Copper/Silver
    Scythe Shuriken Low Profile CPU Cooler
    Zalman CNPS8700 NT, CPU Cooler, Gun Metal Grey
    Zalman CNPS8000 Ultra Silent 92mm CPU Cooler
    Any advice? Do you no of any others? :confused:
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    the silverstone NT06 was developed for there SUGO cases, it was ok at the time but struggled with high end dual cores if i remember, so on a Q9660 i dont think it'll take your breath away.
    scythe shuriken is over priced for its performance, and you might aswell stick with the Intel OEM cooler, which is pretty good actually.
    Cooler Master Gemini II might be you best bet, and it cools your memory!
    Question: Why such a limited height?
  3. icutebluezone
    6 Aug 2007
    Thanks.
    High is limited. Using the Silverstone SUGO SG03 case. The PSU sets over the cpu. See photo below.
  4. tominated
    tominated What's a Dremel?
    28 May 2008
  5. icutebluezone
    6 Aug 2007
    That is a new cooler tominated.
    Cannot get that cooler in NZ. :(
    Cooler Master Gemini II in the sg03 case
  6. Burnout21
    9 Sep 2005
    go on, you know you want to water cool!
    Aircooling and the SUGO series was an issue from the start, even tho the gemini II fits there isn't any room for its fans
  7. icutebluezone
    6 Aug 2007
    LOL. Yeh i have seen 2 watercooled ones before. cramped into the case. Dont really want to spend $$ on water cooling and have to try install it all.
  8. tominated
    28 May 2008
    i'm thinking about trying to get dad to let me make a watercooled sg03 for our next pc (which he keeps delaying)
  9. icutebluezone
    6 Aug 2007
  10. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    have you seen the frostytech low-pro chart? that site's always my first stop (yes, even before bit) when i'm looking for heatsink info.
  11. tominated
    28 May 2008
    where'd you find that one with the swiftech apogee drive? I saw the other, but i was planning on using that block if i do get to build one
  12. icutebluezone
    6 Aug 2007
  13. icutebluezone
    6 Aug 2007
  14. sujanne
    sujanne What's a Dremel?
    18 Sep 2009
