Build Advice Low Spec Build Advice
Discussion in 'Hardware' started by b0ng0, 30 Sep 2010.
  1. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    Building a small(ish), low spec PC for my girlfriend who doesn't need to do much apart from the basics and play a really low spec mmorpg (Dragon Oath). Just wondering if the components below all look okay and if they'll go together. Trying to keep it under £300 (at the moment it's £280 inc. delivery).
    Case: INWIN Z637, Black, micro-ATX Case w/o psu
    Motherboard: Gigabyte GA-MA74GMT-S2, AMD 740G, AM3, PCI-E (x16), DDR3 1333MHz, SATA 3Gbps, SATA RAID, Micro ATX
    CPU: AMD Athlon II X2 250, Regor Core, S AM3, 3.0GHz, 512KB x 2 Cache, FSB/HT 2000MHz, 65W, Retail
    Memory: 2GB Corsair Value Select, DDR3 PC3-10600 (1333) Non-ECC Unbuffered, CAS 9-9-9-24
    GPU: 512MB Asus HD 5450 Silent, PCI-E 2.1 (x16), 800MHz GDDR2, GPU 650MHz, 80 Cores, D-Sub/ DVI-I/ HDMI
    HDD: 500 GB Seagate ST3500418AS Barracuda 7200.12, SATA 3Gb/s, 7200rpm, 16MB Cache, 9.5 ms, NCQ
    DVDRW: Samsung SH-S223C/BEBE 22x DVD±R, 12x DVD±R, DVD+RW x8/-RW x6, SATA, Black, OEM
    PSU: 450W Powercool Modular PSU 80+ Dual 12V V2.2 High Efficiency
    Wireless PCI: Newlink NLWL-PCI02 Wireless PCI Card 11g 54 mps
    Thanks! :thumb:
  2. Tangster
    23 May 2009
    Maybe a slightly better case? The Antec VSK 2000 or Xigmatek Asguard use 120mm fans compared to the 80/90mm fans in the inwin and would better for cooling a passive card and exhausting the air from the stock AMD cooler.
  3. MrTeal
    MrTeal Minimodder
    27 Aug 2010
  4. seanbean
    seanbean Certa Cito
    21 Apr 2010
    +1 for that - don't skimp on a quality PSU'
  5. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I have a similar card to this in my other half's PC (which is admittedly an i5 750 with 4gb ram) and it plays WoW comfortably on medium settings, so I'd say that part at least would be ok.
    However, since you did come in £20 under budget it can't hurt to go the next bump up on the gfx if you can as you never know what MMORPG she might move to in the not too distant future.
  6. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    If it was me i would go for an Asrock N68C-S UCC and a Single Core X140.
    On this board they un-lock to dual core and then run at 3.2ghz without any extra cooling.
    The money you would save could then go on a better graphics card.
    If you can squeeze in a 5670 512mb you would see a massive performance boost.
