Cooling Lowest Sustained Temp
Discussion in 'Hardware' started by JADS, 28 Jul 2002.
  1. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    I was wondering what is the lowest possible sustained temperature achievable with cooling? Not looking for something like Liquid Nitrogen where it lasts for 40seconds or less, but something you can actually use day after day.
  2. George
    George Bah
    14 May 2002
    i dont know an exsact temp, but the vapochill gets CPU's down way into the -C's
    .icecube
  3. JADS
    27 Mar 2001
    Probably around -25oC to -40oC, which is cold, but I would think it would be possible to go lower, say down to -80oC to -100oC? Would that be possible to sustain?
  4. Nexxo
    23 Oct 2001
    Minus 100? Not unless you go for liquid nitrogen setups, which are the domain of laboratories and engineers (just forget about that one, OK guys?). Peltiers will take things down to minus 20 degrees C at most, but issues of condensation make it more hassle than it is worth, IMHO, as for this you exceed overclocking values obtained by water cooling alone by only a small margin. You'd have to look to liquid nitrogen setups for the full whack, which create an effect approaching super-conduction (although not exactly), and then you run into other limitations of the chip (impurities in design/material etc.).
    Good watercooling will get you a sustained and stable +30 C, which is a good operating temperature for a CPU, and allows for overclocking to its practical maximum.
  5. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    Colder is not always better. At least it shouldn't be.
    I remember having a discussion with my semiconductor materials lecturer about cooling processors. I can't remember the exact details of what he said (haven't started revising yet), but it was along the lines of,
    there is a balance to be found between intrinsic and extrinsic carriers in the semiconductor and another property which is also temperature dependent.
    anyway, there reaches a point where further temperature reductions have detrimental effects on performance. He also said this temperature is not as low as you would expect. This is because a amd and intel will often tailor the dopant concentrations to give the best performance around there expected operating temperatures (I'm sure they don't expect everyone to use LN2).
    I'm gonna have to drag my notes out and maybe post again if I've missed something out.
  6. George
    George Bah
    14 May 2002
    but you'd overclock it to its limits, making it as hot as possible, lol.
    .icecube
