Case Mod - In Progress Lucid Dream
Discussion in 'Project Logs' started by AV Case Mods, 26 Feb 2020.
  1. AV Case Mods
    AV Case Mods Minimodder
    31 Oct 2019
    Hello,
    Greetings from finland
    This is my new casemod called Lucid Dream
    Case that i am modding is Silverstone LD03
    My plan is to fit 240mm and 120mm rads for watercooling and do hardline.
    I dont have any components for this build but i update this as soon i get the parts
    Cpu:
    Gpu:
    MB:
    Memory:
    Psu: Silverstone SX800-LTI
    Case: Silverstone LD03
    Watercooling:??
  2. AV Case Mods
    31 Oct 2019
    Here is some pictures of the case:
  3. AV Case Mods
    31 Oct 2019
    For test fitting i 3D printed alphacool radiators.
    Test fitting side 240mm rad with normal 25mm fan but if i use bottom fan as intake i have to go with 15mm slim fans.
    Top radiator will on the outside but it fits under the panel.
    Cheapskate and arduum like this.
  4. arduum
    arduum Minimodder
    10 Mar 2015
    future! :grin::naughty:
    AV Case Mods likes this.
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    If you 3D printed a sort of Lego radiator fitment set that would just be amazing.
  6. AV Case Mods
    31 Oct 2019
    Thats great idea:thumb:
  7. Cheapskate
    13 May 2007
    I'm more of a 'get the radiator and MAKE it fit' person, but that works too. :lol:
    I see the top rad fittings possibly colliding with the side rad's in that configuration. Would it be possible to rotate the top rad so the fittings go through the front?
    -I have one of these cases from drawing up MNPCTech's OuterWorld's mod, so I vaguely have an idea what you would need to do. The front is about 3/4" thick, so it might be possible to re-plate the face and I/O cover plastic with plexiglas, (or a print,) and hollow out a space to run the rad plumbing over the front frame rail.
    Edit: The average radiator outlet tank is 1 inch, right? :worried: OK, that might stick out the front a bit.
    Dot_Kappa likes this.
  8. AV Case Mods
    31 Oct 2019
    There is good change that the fittings collide, but i have backup plan to rotate the rad and i think this way there is no problem.
  9. AV Case Mods
    31 Oct 2019
    I designed and 3D printed new sidepanel for the case with better airflow and same type of design than the top cover:
    Boledile likes this.
  10. Jangalit
    Jangalit What's a Dremel?
    28 Feb 2020
    cool, keep posting updates please :)
  11. AV Case Mods
    31 Oct 2019
    Trying to post more updates but i am waiting for the components so i can do more test fitting.
    Here i some pics of the sidepanel:
    Boledile and Cheapskate like this.
