Scratch Build – In Progress Lucprda - mk1
Discussion in 'Project Logs' started by ldevide, 7 Jan 2020.
  1. ldevide
    ldevide New Member
    13 Nov 2009
    Hi everyone,
    Long time lurker, first time posting...
    Year ago I built a home virtualisation server as a router, file & plex server and it has been running since. As you can see, it's a mess of pre-owned parts, and some cheap components of local substitute for ebay. It was meant to be an experiment, to be replaced by a real server like Dell R720 or HP DL380, but it turned out to work flawlessly so I decided to build it a new case.
    Current case is a stripped HP DC7600 with HP Z400 motherboard, six core Xeon, two LSI SAS controllers and three 1Gbit Ethernet cards. Eight 3,5" drives are obiously too much for that ancient tower.
    It's running ESXi 7.6 U3 with PfSense, Freenas and MacOS virtual machines, all with hardware pass-through (ethernet, SAS, graphics).
    A3AF282D-29B9-4CB7-83E6-D69221920AE8.jpeg 7F94D95C-F582-4619-B385-B2047B0561D0.jpeg
    Since I live in an appartment, with limited resources, the case I designed is in concert with my abilities. Frame of wooden rods 10x10mm, with plywood and plexiglass panels.
    Plexi panels will be laser-cut by local firm, while I'm building the frame. Hopefully, everything will fit in the end.
    For introduction, here are some screenshots of CAD model... Screenshot 2020-01-07 at 12.58.04.png Screenshot 2020-01-07 at 12.57.50.png Screenshot 2020-01-07 at 12.58.17.png Screenshot 2020-01-07 at 12.58.41.png
  2. Cheapskate
    13 May 2007
    Looks promising. :D
  3. ldevide
    ldevide New Member
    13 Nov 2009
    Thanks for the vote of confidence.
    So, I started fabricating the first part: frame for the main ventilators.
    D187C736-ED06-410D-A188-47DD73E6D02A.jpeg 7A7ED94D-CFBE-48B6-9F5A-9E626585B558.jpeg FF37E0E0-B9AB-4E93-B28F-9E797FF5EE6D_1_201_a.jpeg
    I still have a problem finding a PMW fan controller that can handle three of those server fans: 12V, 4.6A. I don't dare attach them to the motherboard headers.
