Case Mod - In Progress | LUMO |-Completed and on In Wins stand at I series...
Discussion in 'Project Logs' started by B NEGATIVE, 15 Sep 2014.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    For the marbling? Black base coat,let it fully dry,36+ hours, then a thin but wet coat of silver then use cling film/saran wrap for the septics and scrunch it up then dab at the silver while its still fresh from the gun,it will look rough but will soften as the paint moves to fill the gapping. Clearcoat will even it out even more.
    Some still think it was paint,even after telling them that i couldnt get the hub off.....:D
    I feel like I let everyone down with the lack of Magoo content,I will make amends with excessive Magoo from here on in :thumb:
    Have you noticed that the 'infant king' of NRK has not been seen for 2 months? And Magoo has put on a kilo.......
    Conspiracy? I think not........
  2. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Really classy implementation of your theme. Love what you did with the mobo. Can't wait to see what you come up with next. :D
  3. B NEGATIVE
    8 Aug 2011
    Thank you.
    And just for you...some Magoo greatness.
    Magoo does not 'do' rain.
    He does do sleep however....
    When he is not planning nuclear war that is,being a dictator is,you know.....hard work.
  4. B NEGATIVE
    8 Aug 2011
    And this one is for Cheaps.
  5. B NEGATIVE
    8 Aug 2011
    Today was all about the RAM.
    Pinstriped and left otherwise untouched.
  6. DBRichard
    DBRichard What's a Dremel?
    6 Apr 2014
    It sure looks amazing, keep it up :) subbed
  7. B NEGATIVE
    8 Aug 2011
    The EK package arrived!
    Lets start with the pump...
    Now,im a well known advocate of the mighty D5 but this build doesnt have the space so I had to go with the DDC. As any watercooling enthusiast will tell you,there are caveats for running DDC's at high speeds,namely keeping it cool. The heatsink kit will go a long way in to doing just that.
    If you are going to have a DDC then go PWM,your pump will thank you for it.
    Fittings and rads were also sent....pics later,you have all seen fittings before but I made the fatal mistake of washing my black background with normal detergent and its ruined for close up stuff,the optical brighteners just shagged it proper for macro stuff...
    Lesson learnt! ​
    Welcome and thanks for looking!
    Good luck with your project.
    :rock:
  8. Cheapskate
    13 May 2007
    Ah, I thought the recent pimp hat and beard were suspicious.
    DDCs can take some heat, but don't wire them backwards!:lol:
  9. B NEGATIVE
    8 Aug 2011
    Did a bit more striping on the finished top to tie it in too.
    I have a new background coming tomorrow,a nice dark grey vinyl,should allow me to make dark shots without having to make severe adjustments to kill the background out.
  10. DBRichard
    6 Apr 2014
    Dude, that stuff looks amazing, totally love it mate :)
  11. ciobanulx
    ciobanulx Modder / Watercooler
    24 Jul 2014
    Love your work mate :D. Can't wait to see more!
  12. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Woof!
    Looks gorgeous. I have to ask though, how much of a pain is it to pin strip in between ridges like that?
  13. B NEGATIVE
    8 Aug 2011
    Thanks,its such a simple mod but looks so good
    And more to come!
    Not that difficult tbh,I measured the slots with a vernier caliper and programmed the cutter to produce strips to suit.
    To place them is simple,I stick one end of the vinyl to the workbench,feed the ram underneath it then draw the stripe along them,if you keep it taut then it will always be straight.
    I can do a video if you wish?
  14. siliconfanatic
    10 Sep 2012
    Not necessary. Was just curious :dremel:
  15. B NEGATIVE
    8 Aug 2011
    The new backdrop arrived today so I took a few quick shots.i think its worked wonders!
    Opinions welcome.
  16. jinq-sea
    15 Oct 2012
    New backdrop looks ace (as does the rest of the build haha) - yellow accents upcoming on the fittings too?
  17. B NEGATIVE
    8 Aug 2011
    Not you too?
    I got deluged in posts on another site about this subject and ,yes,I am.....:D
    This was supposed to be for tomorrow....
  18. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Great photos and great accents!
  19. -MisterX-
    -MisterX- Minimodder
    22 Apr 2014
    Great work and attention to detail. Keep it coming:)
  20. B NEGATIVE
    8 Aug 2011
    Thanks guys,im quite proud of my new found ability,someone asked me for 1440 pics to use as a desktop pic!
    No watercooling loop is complete without control and again I turn to Aquacomputer for their Aquaero 6 Pro controller,provided by my goto watercooling supplier,Specialtech.co.uk.
    I decided against the touchscreen number,mainly as I normally just disable i anyway and this has a better look to it,just the screen and the 3 buttons. The heatsink is on route as we speak.
    I love the functionality of the unit,particularly the IR on/off,it totally declutters the front and carries everything I would want to know about the state of the rig.​
