Case Mod - In Progress | LUMO |-Completed and on In Wins stand at I series...
Discussion in 'Project Logs' started by B NEGATIVE, 15 Sep 2014.
  1. XTSX
    XTSX What's a Dremel?
    12 Jan 2014
    Love your work dude, great jobs !
  2. y0gi
    y0gi What's a Dremel?
    23 Nov 2010
    Never been a fan of that case but what you've done with it looks absolutely stunning. Nice one bro! :thumb:
  3. Cheapskate
    13 May 2007
    Illuminate the mobo tray center.:D
  4. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Don't tell everyone,its a surprise...
    Oh wait....I think I may of already said that's what the plan is.
    I may have to settle for just the res being illuminated tho.
  5. B NEGATIVE
    8 Aug 2011
    As snug as a bug in a rug..Now thats tight!
    I may have to break out the crowbar....
    I will have to take this all into the loft for wider angle shots,my desk is not big enough!​
  6. ciobanulx
    ciobanulx Modder / Watercooler
    24 Jul 2014
    Man that looks so good :thumb:. I love it when things are nice and tight haha
  7. B NEGATIVE
    8 Aug 2011
    The tray was cut at the weekend and is on its way,in the meantime I started on the loom.
    Dark grey Teleios sleeve from E22 with florescent yellow plugs should fit nicely.
    Sadly I ran out of sleeve so its off for more...
    Im getting quite excited about the tray coming now,I will be able to properly assemble the whole tray and get those rads in. I hope I wasnt using my Chinese ruler that day......​
  8. montymole
    montymole Rigid Tubist
    24 May 2010
    You are really in the zone with this its top notch
  9. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Ahhhhh, yet another forum to stalk B Negative on. Delicious. :naughty: Looking spectacular as usual B!! :rock:
  10. Akira749
    Akira749 What's a Dremel?
    12 Jun 2014
    From you, I would be surprised :thumb:
  11. B NEGATIVE
    8 Aug 2011
    The case inspired me massively from the first time I saw it. It was pretty much built in my head before I laid eyes on it.
    I had a plan and ,for once,I stuck to it
    Thank you Sir.
    Magoo has your scent now....and he has the taste for raw flesh.
    You would be surprised how often I misjudge the fitting of stuff,this build had serious space issues which is why the res is in the tray and the ports to it have not been drilled. I bought a pillar drill especially for this tho.
    The advantage is that everything is done in solidworks so its should all slot together well,the disadvantage is that you need good base measurements for that to work.
  12. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Hehe that's exactly what I did too, probably the most nerve wracking thing I've done in my life. Made it all the more tense that the penultimate hole exploded, I wish you much better luck there.
  13. B NEGATIVE
    8 Aug 2011
    I have a technique,drill a pilot then drill in from both sides and meet in the middle.
    Bursting is a bugger with acrylic.
    And for tapping straight if you have a pillar drill,mount the tap and hand start it in the hole then disconnect and use the bar,it will be straight everytime.
  14. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Looking good BN- as ever:hip:
    p.s. good spread in the magazine but again not enough Magoo- the real modding king:grr::D
  15. B NEGATIVE
    8 Aug 2011
    Wut?
    Magoo is indeed the brains of the outfit tho.
  16. hairyknacker
    25 Jan 2012
    Custom PC Magazine? Duude :D:D
  17. B NEGATIVE
    8 Aug 2011
    Its out already?
    Wowzer!
  18. hairyknacker
    25 Jan 2012
    to us subscribers it certainly is my man:rock:
  19. twister7800gtx
    twister7800gtx Minimodder
    2 Nov 2011
    Great works!
  20. Akira749
    12 Jun 2014
    HeyHey :D
    I didn't imagine you were spot on every first time but when you have a piece that big and important custom made, I'm pretty sure that you have double or triple check everything before giving it a go ;)
