Electronics Luxeon LED Suppliers
Discussion in 'Modding' started by SteveyG, 7 Mar 2005.
  1. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Do any of you guys know any cheap suppliers for 1 Watt Luxeon emitters and star LEDs in red, green and royal blue varieties?
    So far CPC and Farnell seem to have the cheapest emitters at about £6.70 inc. VAT for Red, and £8.80 inc. VAT for green and blue.
    Can anyone find or know of anywhere with better prices?
    UK only by the way. Shipping from the US is too much plus I'll end up getting taxed...
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
  3. SteveyG
    23 Nov 2002
    Any of them would do really except for side emitting types, but I need each colour to be of the same type.
    UltraLEDs used to do red and green also, but they don't seem to stock many high flux LEDs anymore :(
  4. mcshaggy
    mcshaggy What's a Dremel?
    28 Mar 2004
    http://www.lsdiodes.com/lumileds/ what about these? i know its US but they have cheap worldwide shipping
    edit: nevermind, i should check my links before posting -_- (but THEY should remove the link from their site! :(.. makin me look dumb)
  5. Mark R
    Mark R What's a Dremel?
    29 May 2002
    I've got most of mine from luxeonstar.com. They're not in the US, so your yankophobia doesn't need to be an issue.
    They are however, in Canada. Depsite this, however, their prices are sufficiently good that they work out equivalent to or cheaper than buying them locally in the UK, even with tax and postage. Postage has been about US$10 for 10 LEDs, when I've ordered.
    Also, HMC&E have been a bit slack recently, as about half my packages have got through with no tax at all. The main problem with tax though, is not the tax itself, but Royal Mail's 'collection charge'.
    If you're ordering 10 LEDs at a time, then even with tax, handling charges and postage, you can save nearly £1 per LED.
  6. bwgames
    bwgames Minimodder
    6 Dec 2004
    On a related note, is there such a thing as UV Luxeons? I want some bright UV lighting for my machine :D
  7. g0th
    g0th What's a Dremel?
    12 Apr 2005
    Purple or UV high-flux LED's of any sort would be cool.
  8. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    What about World-Led?
    It's in the Netherlands, they deliver to the UK and seem to have good prices and quite cheap shipping costs.
    CD :)
  9. coorz
    coorz Miffed
    25 Apr 2003
  10. SteveyG
    23 Nov 2002
    I dislike the ProLight clones due to the variable polarity of the slug, which makes heatsinking more than one such a pain.
  11. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    ebay is often a good place, remeber it has to be above a certain amount before they inport dutey you!
    i've given into the prolight's new RGB one, and ordered 4, i'll let you know my verdict if you like (won't be till after exams i get a chance to work them!)
  12. SteveyG
    23 Nov 2002
    That would be useful, I've used several of the Prolight LEDs, but not the RGB ones.
    Thanks
  13. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    yup, just waiting for the chinease labour week backlog to clear...... and my exams to be over.
    oh why did i curse myself with software engineering (design, too boring to revise), neurosience and furhter cybernetic systems!
