Modding LW-200 Case
Discussion in 'Modding' started by bumfluff, 31 Aug 2006.
  1. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Ok, I acquired an LW-200 Wordprocessor Case From School today, and it is fairly large so could at least fit a Micro-ATX board so could make a reasonable computer. I am trying to flatten out the insides and was wondering what the best tool to do this as it is not very accessible, although that will be easier once I have managed to get the rail out of the way that is left inside.
  2. brumster
    brumster What's a Dremel?
    13 Jun 2002
    Use a dremel + flexshaft to cut it all away?
  3. bumfluff
    18 Aug 2006
    I don't really want to have to buy anythinglike aflexishaft, just some tool that I will likely have?
  4. bumfluff
    18 Aug 2006
    This is taking an age to cut as the only tools I am using at the moment are a hacksaw (which is difficult with the limited space around the edges and a Dremel which doesn't really cut very much.
    Any help?
  5. Blame582
    Blame582 What's a Dremel?
    24 Apr 2003
    sawsall or jigsaw maybe work better
  6. bumfluff
    18 Aug 2006
    What is a sawsall?
  7. Blame582
    24 Apr 2003
  8. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    What attachment are you using with the dremel and what exactly are you trying to cut? A picture would help with us to see what you're actually doing. If you don;t want to get a flex shaft, nothing suggested here so far will be affordable either, although the jigsaw would be the best bet since the sawsall (i have one of the ones on that link) is usually used for rougher and bigger projects.
  9. bumfluff
    18 Aug 2006
    I have plenty of tools, just not spare bits for the Dremel, what sort of cutting disc is best? At the moment I only really have a Metal Cutting disc.
  10. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    IMO - diamond discs (Dremel part no: 545) are the best ;)
  11. bumfluff
    18 Aug 2006
    Well I got a heavy duty cutting disc today, I think Diamond will be a bit expensive but the set includes some of the fibreglass reinforced blades which were recommended in a tutorial.
  12. bumfluff
    18 Aug 2006
    Ok, my collets (if that is the right part) arent big enough for the shaft supplied, is it ok if I use a slightly thinner shaft as its not like I am cutting a very tough material.
