Watercooling m-atx watercooling
Discussion in 'Hardware' started by donok, 4 Jun 2012.
  1. donok
    donok Every Little Helps .....
    16 Feb 2011
    how would temps be on a
    i5 3750k alone v i5 3750k and gtx 670
    on a 240mm rad
    regards
  2. bulldogjeff
    2 Mar 2010
    At a guess I would say not a hell of a lot better than decent air cooling. The 3750 does tend to run a bit hot when it's over clocked so would benefit from being watercooled. On the other hand the i5 runs a lot cooler so would benefit less, but in a loop with the 670 it would be worth the effort and it will look good as well.
  3. law99
    law99 Custom User Title
    24 Sep 2009
    Definitely always looks better.
  4. donok
    16 Feb 2011
    thinking just doing the cpu as its much less effort then dismantling a gpu.
    also no waterblocks for gtx 670 asus dcu2
    both ivy setups just to include the gpu or not
  5. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    No waterblock yet. EK are currently working on one. It'll be about a month off at most, though.
  6. donok
    16 Feb 2011
  7. donok
    16 Feb 2011
