Motherboards M/Board automatically boots up
Discussion in 'Tech Support' started by Espie79, 25 Sep 2011.
  1. Espie79
    Espie79 What's a Dremel?
    17 Aug 2011
    Hi all,
    I am having an issue I believe with my motherboard. Basically, as soon as I turn the switch on my PSU to on, the computer starts up without pressing the power button. It wasn't doing this before but now every time I turn on the PSU it boots up.
    The PSU is new, it is a Thermaltake XT 675w and I have disconnected everthing from the motherboard except the CPU and fan. No idea what is going on. Hopefully someone can help.
  2. Guest-16
    Guest-16 Guest
    Basically the PSU causes a power spike that jolts the board into powering on. Or maybe there's a case short.
    Q: why do you switch the PSU off at the back?
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    A: Because he can't turn it off at the front of the case? lol
    Anyway, yeah, check for any shorts between case and motherboard.
  4. longweight
    7 May 2011
    Who turns the PC off from the front?
  5. Pookeyhead
    30 Jan 2004
    There's usually a BIOS setting to dictate what happens when power is restored after a power cut. One option is power on. So basically, if you switch off the PSU at the back, when you switch it back on the machine is assuming there's been a power cut, power is now restored, so it boots up.
    Check your BIOS. My Asus P6 had it, and my current Gigabyte piece of crap has it as well.
    It's not really necessary to switch off the PSU though.
  6. Espie79
    17 Aug 2011
    Thanks for all the comments. Couldn't work out the problem so I put a different motherboard in and problem solved. I don't usually turn the PSU off but I was testing my setup and installing parts.
  7. Pookeyhead
    30 Jan 2004
    Glad it's sorted.... but it was probably the BIOS restore power settings, and there was nothing wrong with the board.
