Case Mod - In Progress M-ITX build
Discussion in 'Project Logs' started by Kronos, 6 Sep 2013.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    This is not really a fresh build as most of the parts I have either been using or had spare but maybe bought the odd thing.
    RAM: G-SKILL RIPJAW X 2x4GB 1.5v 1600MHZ DDR3 RAM
    CPU: I5 2500K
    Mobo: P8H61-1 LX R 2.0
    GPU: Asus Direct CU 11 GTX 670
    PSU: SST-ST60F-P PSU
    SSD: 128GB M4
    HDD: 2 x 1TB
    Couple of extra fans.
    PSU extender.
    Showing the added BitFenix Spectre140mm fan.
    This with the added Antec TrueQuiet 120mm fan.
    Going to be using a Arctic Freezer 11LP quite like these.
    As cable management is important in a small build I have got myself 3 x 300mm round Sata cables and 3 x 450mm not sure which will work for the best.
    This is a lian Li PSU extender which was once silver but I have painted black. Gives more space in the case and hopefully a better airflow.
    Can anyone offer any suggestions to improve any aspect of this build?
