Apple mac alternative to super C
Discussion in 'Software' started by sotu1, 6 Sep 2008.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hey guys, does anyone know of a tool that will convert video file formats? I use Super C on my windows PC but I'm now looking for a mac alternative. Main use will be converting videos to be compatible with my DS (DPG file format) and eventually my PSP (when I get round to figuring out how it all works!)
    cheers guys!
  2. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    ok, rephrasing this because there must be something out there:
    is there something on mac that can convert video file formats?
  3. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    Handbrake? VLC can transcode as well. There's a couple other apps.
  4. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    ffmpeg directly with command line, so you can do a script and just click on it to convert all file in a folder, much faster than playing in an interface when you got the script (it is not hard to make, ffmpeg command look like "ffmpeg movie.avi -h 240 -w 320 -o movie.m4v" for ipod/psp
  5. koola
    koola Minimodder
    11 Jul 2004
  6. adam197
    adam197 What's a Dremel?
    22 Feb 2005
    Theres also ffmpegX with a (reasonably) nice UI if command line isnt your cup of tea.
    I also quite like iSquint. Very handy for iPod compatible videos and Im sure you can use the advanced settings to suit your DS / PSP.
