Apple Mac Book Pro Upgradeability?
Discussion in 'Hardware' started by geoboy333, 18 Sep 2011.
  1. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    Hi Guys
    as some of you know I'm planning on getting a Mac Book Pro for uni to study music production.
    Therefore I'd be wanting a laptop that can handle quite intensive applications and VSTi/RTAS.
    I was wondering whether I'd be able to uprgade the mac book with these two items in order to make it better suited.
    2x http://www.scan.co.uk/products/8gb-...0-(1066)-non-ecc-unbuffered-cas-7-7-7-20-150v
    http://www.scan.co.uk/products/1tb-...25-95-mm-sata-ii-3gb-s-5400rpm-8mb-cache-55ms
    would that be possible? I realise I'd have to reinstall the OS but my main qeury is, would the Mac OS recognise 16GB of RAM?
  2. Cei
    Cei pew pew pew
    22 Mar 2008
    Yes, you can easily swap RAM and HDs. Doesn't invalidate your warranty either, as long as you don't balls it up.
  3. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    As of Snow Leopard, OS X is 64-bit by default, so I'm almost certain it'll be fine with 16GB of RAM. From experience though, music production is more CPU-bound than RAM, as the effects you place on each channel have to be processed before they're fed through your audio board.
    You also shouldn't need to re-install the OS, you can create a backup of your OS using Time Machine (or do it the dirty way using Disk Utility and back up to a DMG) and then just restore back onto your new drive. I've upgraded my 160GB 5200rpm drive to a bog-standard 320GB 7200rpm with no issues so the 1TB WD should be fine :)
  4. faugusztin
    11 Aug 2008
  5. DaveMon
    DaveMon The end is nigh! Repent!
    21 Jun 2010
    You can use carbon copier cloner to transfer to a new hard drive. Connect up the new drive using a usb caddie, I used this to transfer to my ssd. dead easy and copied over in about 20 minutes.
    Sent from Bittech Android app
  6. Hutchy
    Hutchy New Member
    7 Jul 2003
    As Cei said, it's really easy to double your memory without paying Apple prices. Unscrew the small back panel and slot it in!
  7. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    What dave said - Carbon Copy Cloner is just the ticket to copy your drive. I did the same as him when I upgraded my MBP to an SSD and maxed out the memory to 8GB.
    If you want to know exactly what memory config / max addressable your particular MBP will have, take a trip to the Crucial site and use their memory advisor tool - either download their app to the machine when you get it, and let it do it's stuff, or select the correct MBP on the online system.
  8. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
  9. geoboy333
    28 Sep 2009
    @faugusztin thanks, didn't realise that it was a two DIMM kit. drat. Is there a 16GB kit out there?
  10. faugusztin
    11 Aug 2008
    AFAIK no. The first desktop 8GB modules are showing up (8GB server memory modules with ECC were present for long time), but i have yet to see a 8GB SO-DIMM DDR3 memory module.
  11. saspro
    saspro IT monkey
    23 Apr 2009
    8gb is the maximum a MBP will take
  12. GreatOldOne
    29 Jan 2002
    Is that still the case? I know 8GB was the max on my MBP, but it's a 2009 model.
  13. faugusztin
    11 Aug 2008
    Well, there are simply no bigger memory modules, so your question is sort of pointless :).
  14. saspro
    saspro IT monkey
    23 Apr 2009
    I've got the 2011 model & 8GB is the limit on mine
  15. -=ice=-
    -=ice=- New Member
    17 Jan 2003
    saspro likes this.
  16. saspro
    saspro IT monkey
    23 Apr 2009
  17. geoboy333
    28 Sep 2009
    tis handy but WTF $879 dollars?!!!?!!!?! thats nearly as much as the effin computer!
  18. faugusztin
    11 Aug 2008
    The reason for that price is same as why 8GB DDR3 desktop modules are 170 euro per piece - low production volume so far, so the price is really high. It will come down in time.
